Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 02-15-2006, 09:29 PM
stacyc219 stacyc219 is offline
2000 Beetle low beams
I'm having problems with low beams. They're not working. Changed bulbs, checked fuses, what else? High beams and all other lights are okay. Any ideas would be greatly appreciated.
Old 02-17-2006, 06:51 AM
hako hako is offline
Re: 2000 Beetle low beams
There should be a relay which changes high to low beam when you select. Not sure where it is located but if working you should hear a click when you use the hi/lo beam selector arm.
Old 02-18-2006, 03:23 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
the harness are known to be a problem on early beetles. the small 10.00 harness that plugs into the headlamp then into the low beam bulb
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
