Old 02-15-2006, 08:28 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Code 43
Alright, i got a 93 Civic Si, paid $100 for it, had to swap out heads(broke valve) and time it a dozen times, and believe its timed, or atleast on the right tooth, don't have a timing light to do the ignition timing at the dizzy. The car is a race car for the 1/2 dirt track in my back yard. Well when i first got it running, I took it out on the track and didn't have too many problems, seemed like it could go faster, but other than that, no codes or anything. Today I swapped wheels, put some 87 teg aluminum wheels on, put a makeshift intake tube and filter on(big piece of rubber tube from a ford ranger and a cone filter). Took the car out on the track and did exceptional for a couple laps, then all of a sudden around 4500 rpms it starts bouncing back and forth, like it hit a rev limit. I pulled it off to the side and checked the codes and I'm coming up with Code 43. Any suggestions? I know its a code about fuel pressure, figured I would check here and see if anyone has ran into this problem yet and what it was. Any help is greatly appreciated.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-15-2006, 10:28 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Code 43
tighten gas cap and reset cel. if problem returns, get some fuel pressure readings.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-16-2006, 05:53 PM
Tony's Avatar
TLD Member #1
Re: Code 43
Well i haven't really known a loose gas cap to cause that big of a problem, but ill check just to make sure, and I also grabbed a regulator from work, so ill replace that too and hopefully that will get it.
Tony
Old 02-16-2006, 10:06 PM
snowman2005's Avatar
snowman2005 snowman2005 is offline
Send a message via AIM to snowman2005
Re: Code 43
does ur fuel pump work?
ive got manuals
92-95 civic 96-98 Civic
clicky here clicky here
WTB:92-95 EX/SI cluster w/tach
FS:*NEW* 92-95 civic coupe black floor mats(4). pm me for pics or offers
Old 02-17-2006, 06:14 PM
Tony's Avatar
TLD Member #1
Re: Code 43
Yea, pump works. I replaced the regulator yesterday and that seemed to do the job. Took it around the track a couple times with no problem, now just gotta fix some other odds and ends.
Shouldn't have really posted this thread, i get a little anxious sometimes, but maybe someone can use it sometime.
Tony
