Old 02-15-2006, 08:05 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
time in between sets
I was wondering how much time i should spend resting in between sets.
My routine right now is:
Curls (35lbs) 3 sets (decreasing reps starting at 8)
military press (35lbs) 3 sets (decreasing reps starting at 8)
shrugs (50lbs each hand, need more weight but left it at home) 3-4 sets (10 reps)
bent over rows (see shrugs) 3 sets (10 reps)
ab excercises (depending on my mood ill switch it up between 3 different excercises) 3-4 sets of 20-30 reps
forearms (20lbs) 3 sets (10 reps)
between sets i spend time stretching, then about 20 seconds resting, then the next set, between excercises i just change the weight on the dumbells and go right into it. should i leave more or less time between sets.
I'm 17 (almost 18) ~185lbs 5' 8.5" my goal is to lose some weight and bulk up. First i want to get as bulky as i can, or until i think it's enough, then get toned and lose weight. i don't really have enough time to do alot of cardio right now so ill just have to diet and hope i lose a bit of weight while i wait for the summer (knees are shot so i cant run, biking and swimming are the only real cardio i can do).
also, i can't do leg presses or squats because of my knees (5 years ago i could leg press 250lbs, now i cant do 200 without my knees killing me) so do any of you know some leg excercises that i could do?
Mr. T doesn't pity anyone who likes the Black Eyed Peas. He just kills them.
Mr. T speaks only when necessary. His main form of communication is folding his arms and slowly shaking his head. And regardless of the situation, he is always understood.
On the A-team, Face , Haniabal, and Murdoch were all masters of disguise. Mr T didn't have to wear a disguise. The bad guys didn't recognize him out of fear.
Old 02-15-2006, 09:37 PM
sivic02's Avatar
sivic02 sivic02 is offline
Re: time in between sets
If you are going to failure in each set then about 2 minutes between sets. Dont stretch between sets. Stretching reduces the ammount of weight you are able to toss up. Dont get me wrong stretching is an important part of any exercise routine but if your looking to bulk up then it should be done after lifting or on another day completely.
Here's to being single, seeing double, and sleeping triple
Old 02-15-2006, 10:39 PM
nissan_240sx nissan_240sx is offline
Try leg curls, biking (esp. up hills in high gear), or running.
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 02-16-2006, 12:47 PM
Gohan Ryu Gohan Ryu is offline
Every trainer I've heard says no more than 1 minute between sets - and don't stretch between sets.
