Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX > Technical
Technical Discuss Engine, Suspension, Drivetrain, and all other technical issues here.
Old 02-15-2006, 08:57 PM
Skylindrftr Skylindrftr is offline
Send a message via AIM to Skylindrftr
Throttle Position Sensor (TPS) Adjustment
My other thread isnt getting much attention, so heres one that if supplied with the correct info could solve most peoples tps woes and it could be stickied so we wouldnt have any more ques on this.
First off when I took off the thermo housing I had to take off the tps sensor and unplug it to get to a bolt. This apparently messed with something b/c now my idle is erratic, my engine bogs, has not torque and is jerky at anything but no or full throttle. Considering that I ran 264 cams on both sides before and didn't have idling issues tells me there is something deffinately wrong. If anyone has an info to contribute it would be good. (sr20det redtop btw)
Old 02-16-2006, 05:00 AM
stang805's Avatar
stang805 stang805 is offline
Send a message via Yahoo to stang805
Re: Throttle Position Sensor (TPS) Adjustment
sounds like you put it back on wrong or messed it up in the process, take it back off and pay very close attention to where the peg thingys are, its made to turn with the throttle body butterfly, line it up so when you open the throttle it will turn the tps, its that easy, if its lined up right and still actin funny you can check it with a multimeter, a haynes or chiltons or i'm sure someone on here can give you the proper readings, if all that checks out you broke somthin else.
Old 02-16-2006, 05:58 PM
Yeah I put it back exactly and was going to check it with a multimeter next, but I wasn't sure if you were supposed to do this with the car on and if it is like that I can't do it b/c I tried to start with with the harness unplugged and it died...
Old 02-17-2006, 07:39 PM
bump, please help I want my car running good soon...
Old 02-18-2006, 12:49 PM
driftking777's Avatar
driftking777 driftking777 is offline
Send a message via AIM to driftking777 Send a message via MSN to driftking777
your car died when you started it with the tps unplugged? weird...i could drive around with my tps unhooked and it drove better than when it was hooked...bought a new tps, and calibrated it (by ear..lol) and now its good to go. BTW...with a multiM...it should run around .05 volts at idle. you test it by pluggin positive to the top wire, and neg to the middle wire ...someone correct me if im wrong
Current cars:
83 RX7: KA-T, t3/t4 turbo,Tial 38mm WG, MR coilovers, 5 lug conversion all around, TII brakes, hydraulic hand brake, 8" rear", 6 point cage, AMS Rebuild kit, Fully ported polished race head, Custom interior, JLine 6LR2 15x8, 16x9.5
Old 02-18-2006, 05:21 PM
Cool thanks i'll try to idle it today with it off i guess, but it didnt work last time i dont know if itll work now, it goes down to 800, then 300, then dies...
Old 02-21-2006, 01:43 AM
nissan_240sx nissan_240sx is offline
any update on the prob dude?
-Matt
NISMO
1992 240sx SE Fastback 5speed
Old 02-22-2006, 10:25 PM
well seeing as i apparently put the thermo in wrong or something and coolant is pouring out of 3 places I will fix that first!
Old 02-23-2006, 09:03 PM
arg I just overtq'd a bolt and it broke of leaving 2mm to get it out...
it only took me an hour to get out bleh...im an idiot
When putting in the thermo, where should you put gasket filler, just on front side of thermo housing around the indentation?
