Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-15-2006, 07:24 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Buying head for rebuild
Hey all;
I'm buying Travis' head off his car and I'm going to rebuild it. I've always wanted to do this, but I don't know where to start. I want to get it ported and get some kickass flow. I know its oging to be expensive, so I'm not doing anything for awhile yet. But can someone point me in a direction to look at? Like parts, and places to get it ported. Thanks!!
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-17-2006, 12:22 AM
david-b's Avatar
Dave is THAT guy
Question Re: Buying head for rebuild
Anyone??? No info??
Do I need new head bolts then?
Where can I send for porting?
Do I certain valves and springs then for after the port?
75 Monte Carlo
Old 02-17-2006, 06:53 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Yes you'll need new head bolts.
I ported my head myself, it's actually quite easy.
http://www.sa-motorsports.com/diyport.shtm
http://www.chevyhiperformance.com/techarticles/95518/
Just don't get port crazy and port it TOO much.
I used a variable speed die grinder with an assortment of different bits. You don't need to replace any of head components. Actually Hahn has a 420a doing 10's on a stock head! The 420a heads are actually quite strong. I think I'm going to throw in some cams when I get to working on mine again, but for what you want, you shouldn't need to replace anything.
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2006, 07:48 AM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
I'd cam the bitch if I were you. I dont know 420a heads, but I would go with some better springs and retainers so you can rev it out a little and not have to worry about valve float.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-17-2006, 07:59 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
ITS OFF
theres a pic of the vaulves
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-17-2006, 02:01 PM
david-b's Avatar
Dave is THAT guy
Very nice Travis
So I can use the stock valves and everything even after porting?
75 Monte Carlo
Old 02-17-2006, 02:17 PM
Originally Posted by david-b
Very nice Travis
Yepp. If Hahn uses the stock head on a 10 sec. boosted car, I think we can use the stockers on just a ported head.
Woohoo, post number 1600 baby. Only 400 more till 2k.
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2006, 04:54 PM
david-b's Avatar
Dave is THAT guy
But arent you making the holes bigger? How will the stock valves and all still fit when everything else is bigger. Seems like it would all fall apart.
75 Monte Carlo
Old 02-17-2006, 10:12 PM
No, don't make the valve ports bigger, just the intake and exhaust ports. When most people port heads, they usually just port the intake and exhaust manifolds. I don't think I've ever heard of anyone porting the "valve ports."
95 Talon TSI AWD
97 Eclipse GST
Old 02-17-2006, 11:17 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
i need to sell a 1g head
DSM geek
Old 02-18-2006, 12:40 AM
david-b's Avatar
Dave is THAT guy
Ahhh... i had the wrong idea then. So its just the intake/exhaust runners then? I can't wait to get this going.
75 Monte Carlo
Old 02-18-2006, 12:51 AM
defiancy's Avatar
defiancy defiancy is offline
Stay classy San Diego
Here are some things you can do to your head if you want
- Polished Stainless Steel Valves
- Bronze Valve Guides
- New Valve Stem Seals
- Crower Valve Springs & Titanium Retainers
- New Rocker Arms
- New Hydraulic Lifters
- Performance Valve Job
- Head resurfaced
- Intake Porting
- Combustion Chamber work
Its pricey, but you don't have to do everything.
1991 GSX 2.3 Stroker
