Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 02-15-2006, 05:46 PM
skatendestroy skatendestroy is offline
Send a message via AIM to skatendestroy
fuel tank and fuel injector ?'s
I Switched my 95 neons fuel tank fuel pump and what ever the silver thingy that bolts to the car is (its got two lines one from fuel tank and other to the motor. the new fuel pump is outta my parts car its a 98 neon
i took the tank the lines from tank to that silver thingy that silver thingy ityself that bolts to the frame and the pump and the evap lines since in the process of diconnecting them i snaped the plastic connectors
Does this fuel pump put out a higher pressure then a 95 fuel pump am i going to have to change over my injectors and plugs since i switched to a todaly different fuel tank setup?
thanks again
sean
Old 02-15-2006, 10:17 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: fuel tank and fuel injector ?'s
No you shouldn't have to change your injectors or plugs. In fact, the injectors might not fit, but I can't be sure on that. Or maybe it's the fuel rail that is different, I can't remember. But you should be fine.
Old 02-16-2006, 07:47 PM
yea the connecotors are different so id have to re wire them in but they do fit though.
thanks again
