Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 02-15-2006, 03:43 PM
99zhfkaf 99zhfkaf is offline
ac fan switch problems
I have a 99 passport w/ac that has worked fine for the 2 years I've had it. Now when I move the fan switch from off to 1, 2, or 3 I have no problems. Blue "ac" light is on and car is blowing cold. When I switch to position 4 on the fan selector, the fan kicks up a notch like it should, but the blue light goes out and the air that comes out isn't nearly as cold as with any other fan switch position. any ideas?
Old 02-28-2006, 03:48 PM
Re: ac fan switch problems
i can't live in AZ without my ac's "4th gear" blowing cold. any ideas at all?
Old 03-01-2006, 12:56 PM
rodeo02 rodeo02 is offline
That is really weird, 'cause the blower speeds and a/c switch are totally seperate. The only thing I can figure is, on speed 4, so many amps are being drawn that the a/c is tripping off (relay cant hold-in). The blower motor is a HIGH electrical draw item. A (new) higher capacity battery or maybe a new alternator *could* be the fix. I'd start by swapping relays around just to rule that out.
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 03-01-2006, 05:47 PM
thanx for the idea '02. My battery is old and I was going to replace it before this summer anyway. I also have a 500w fosgate amp and aftermarket fog lights that are always running as well, drawing extra electricity. so all that may be contributing to my issue.
Old 03-06-2006, 08:35 PM
Jammer369 Jammer369 is offline
I have the exact same situation with my 99' rodeo. Everything works great in speeds 1,2,3 but no go with 4. The A/C compressor shuts down. It will come back on if I put the fan switch back to 3. I do have a new battery so that rules that our for me.
99zhfkaf - Did you get yours fixed?
Thanks,
Troy
