Old 02-15-2006, 03:09 PM
arpin arpin is offline
is it my ccrm
i have a 95 windstar and i can not for the life of me get it to start.
i have changed the comp,fuel pump,fuel fil,fuel press reg, and still no glimer of hope.
when i spray starter fluied in the intake it starts and runs for a second.
but its like its not getting any fuel pressure.
so i was wondering if it could be the ccrm.
thanks for reading.
Old 02-15-2006, 04:49 PM
wiswind wiswind is offline
Re: is it my ccrm
It could be, as the fuel pump relay is in there.
I have pictures of the CCRM in my pictures at
http://community.webshots.com/album/201931518cScpNK
Old 02-15-2006, 05:06 PM
Re: is it my ccrm
i already have the ccrm out and im going to the junk yard later.
i would like to get a new one but it looks like a dealer part
and well i know they charge a arm and a leg.
thank you for the fast re:
i will follow up when i put the part in
Old 02-15-2006, 05:10 PM
Re: is it my ccrm
I bought mine at Millennium Ford in Seattle over the web.
They seem to have good prices, and gave me very good service.
The new part is a different part number as they improved the sealing of the relays. You want to make sure that you get the correct one for your year / engine.
Old 02-16-2006, 01:10 AM
Re: is it my ccrm
well i put the new/old ccrm in and i seem to have better fuel press,
but she just wont turn over for me. i think shes a lesbian.
i ready to finace a bazooka and thust no more probs.
any who any sugs would be great. thanks for all the help
Old 02-16-2006, 07:13 AM
garync1 garync1 is offline
Re: is it my ccrm
I am going to throw this in there but you may have fixed the problem with the above items. You know it starts with starting fluid. With little spark it will fire up starting fluid.But not gasoline. You may need to dry out your spark plugs or changed them out. Also make sure you have a full charge on the battery you may have a weak spark that does not wont to fire the gasoline.
Old 02-16-2006, 02:17 PM
Re: is it my ccrm
thank you for all the help!!!!!!!!
Old 02-16-2006, 03:07 PM
floridatgp floridatgp is offline
Re: is it my ccrm
IF this van has one, maybe a crankshaft sensor, if it doesn't think the engine is turning over, it may not try to pulse fuel injectors. See if they are getting pulsed. I would think you could just pull plug from one injectore and monitor with voltmeter
Old 02-16-2006, 03:52 PM
Re: is it my ccrm
i do not have a volt meter nore do i know where the crank shaft sen/ is
i going to try to pull the spark plugs out and clean them up
hopefully its this simple but it never is.
man this van is more high mate-then my wife!
i like the idea of lots of room in the van,but theres not enough in the eng area.
thank you again. lots of help!
Old 02-17-2006, 07:11 AM
phordguy phordguy is offline
Re: is it my ccrm
You need to find out if the injectors are getting pulsed while cranking. Find yourself a "noid" light and see if they pulse while cranking. If they do not, well you know you have other issues on the ECM side or v/r edis sensor or wiring! What's the static fuel pressure like with the vacuum line off the regulator?
I had similar problems with a mustang, turned out to be my injectors. When I pulled them out they were so dirty they looked like they had been buried under the junkyard for a few years. I put in another set of refurbished ones and dried the plugs. The car cranked on the first try!
Old 02-17-2006, 03:30 PM
Re: is it my ccrm
i was wondering if there is any way to clean up the injecters without replacing them.
im just a little short on cash
or any kind of backyard tricks to do.
also i dont know what a noid is or even where it is
thanks for your help
Old 02-17-2006, 03:43 PM
Re: is it my ccrm
A noid light set is basically a test light that plugs into the injector harnes instead of the injector. When you crank you should see the noid light flash. Harbor Freight has a set for $20. Last time I bought used cleaned injectors from a reputable guy on ebay that had an overstock, 6 for $50. I'm sure you can pull them out and run some concentrated carb cleaner through them and then replace the o rings and pintle caps and washers ($5~10 total for each injector) from parts from Napa, but in my case $50 was easier and just as cheap.
Here's the noid light set at HF:
http://www.harborfreight.com/cpi/cta...emnumber=92667
I'll look and see if I can find a reference to what lb per hour these injectors your 95 uses. Ebay or a pick and pull will have 'em. You could buy one injector and rotate it around the possible 6 positions to find your clogged one if that's the case (and/or read the plugs).
Old 02-17-2006, 04:05 PM
Re: is it my ccrm
Here's a used set for $46 for a 95 windstar, pretty much the going rate but from a salvage yard: http://cgi.ebay.com/ebaymotors/1995-...spagenameZWDVW
I think we can do better on the price though and will keep my eye out for you.
Old 02-17-2006, 04:35 PM
Re: is it my ccrm
I really appreciate all of the replies
and all of the help
i will post when i clean the injectors
thanks again!
Old 02-17-2006, 07:16 PM
Re: is it my ccrm
I had to remove mine to clean the spray end. The rest was clean.....but for some reason, I was unable to clean the spray end with the fuel system cleaner that you put into the tank. Just a squirt of cleaner onto the spray end flushed all the crud away....and the vehicle ran much better.
I have pictures of the injectors in my pictures at http://community.webshots.com/album/201931518cScpNK
My problem was a slight miss. I do not know if it would suddenly cause the problem that you are having.
