No heat from my '04!
Driving to work this morning, I noticed that my Impala was not pumping out any heat. Of course it had to be only like 13 degrees. Anyhow, engine temp was normal. What/how should I check 1st? I am needing to take this car on a long drive tomorrow. Just my luck. I do not think it is heater core as I do not smell any hint of coolant inside the car. Any quick help with some diagnostics would be great!
2004 LS 3.8 |
Re: No heat from my '04!
Your heater core could be blocked, or done. I'd definetly try flushing it out before replacing it.
2000 Chevrolet Silverado Regular Cab Short Box 4.3L Vortec - 5 speed Ion Alloy 16x8" chrome wheels Magnaflow Catback Exhaust K&N Intake, Throttle Body Spacer ![]() GM Automotive Technician Previously - 2003 Chevrolet Cavalier |
It could also be the vent or valve which changes the air from hot to cold.Did you turn it down and then back up .I think they are controlled by vacuum.(just a possibility)
Hey Fellas,
Thanks for the responses! I did have to take it in to the dealer to get it checked out as I was short on time with having to go out of town. Sure enough, after the dealer had the car for 5 hours, they figured out that there was either an air bubble stuck in the heater core or sediment build up. Either case, after a good back flushing the heater was once again kicking out a hot 140 degrees. |
----------- what could cause this? seems not usual |
If I had to guess, it was one of two things;
When I checked the overflow tank, it wasn't empty but it was low. I think that the system was sucking air. I also noticed that the overflow's cap was off possible sucking in dust through the system. I guess I will have to keep an eye on the level of the overflow though I though there would be a light on the message center telling me that I had low coolant. Thanks for the responses! |
