Old 02-15-2006, 12:21 PM
texwill texwill is offline
SOHC Performance?
I was wondering if there is any cam or bolt on performance mods I can do to my 89 Civic 4dr. 1.5l, I understand the fact that an engine swap is the best thing to do but I am stationed overseas in Germany and have not had any engines come my way. I have all the regular bolt ons, intake, cat back exhaust, MSD ignition and all suspension mods. I want to keep it somewhat streetable but just looking for some extra power. I just aquired an MPFI intake, wiring and ECU and downloaded the directions. I just figured there are things you guys are doing that might help, like cam or something. Thanks
Old 02-15-2006, 12:30 PM
Kven's Avatar
Kven Kven is offline
Re: SOHC Performance?
Put a VTEC head on there? It's pretty straight forward. As far as cams go; If you stay non-VTEC, there are Delta regrinds that cost like $60(you send them the core).
HondaSwap | K20A.org | EF Honda
1988 Honda CRX DX
WTB: CRX mudflaps(both front and rear)...PM me if you have some for sale!!!
Old 02-15-2006, 01:42 PM
Exempt Exempt is offline
Send a message via AIM to Exempt Send a message via Yahoo to Exempt
Honestly bro, for the price u paid for all that you could have had a D16A6 swap, which would net you more power than tha D15B with all the bolt ons... Its just not worth investing in for the few ponies u may (but probably wont) gain...
And the fact that your in Germany hell, just makes it easier for you to find a swap... They have the D16/A8/A9/Z5s (DOHC ZC) and B16A stock there, and im sure theyre much cheaper than you can get them here for... Plus you get a discount in shipping (being in the Military), im sure u could find a way to get it brought back to the states for much cheaper than it would be to buy one here... Just a thought...
Old 02-15-2006, 03:59 PM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Get an underdrive pulley set and lightweight flywheel.
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 02-15-2006, 07:13 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
I agree, getting an A6 would be better, but your bolt on's shouldn't be a waste either, most of it should swap over to the a6, so it wasn't a waste of money. But if your gonna get another cam, i would go ahead and do a Mini-me swap and go ahead and change the head on it. As for a underdrive pulley set, make sure you get a reputable brand that has done their research and makes sure its all still balanced, otherwise you could end up with one that isn't balanced and does more damage than its worth. Ive heard Unorthodox makes good pulleys, don't know about the rest, ive just heard a few horror stories about un balanced ones. But a lightweight flywheel is always a good idea.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 02-15-2006, 09:29 PM
duffman868 duffman868 is offline
while some might disagree stay with the head you have it is the same as an a6 with a crappy cam. now go get an a6 cam and send it to delta for a regrind and get some head work. get some d16a1 pistons and throw them in a d16 block. then swap out bottom end and throw on an aftermarket or ported intake manifold. this should net roughly about 120-130 whp maybe more depending if you tune it alot. comparing it to the roghly 60-70 you have now it would be a fun little car
i just noticed you are in germany so i dont know how much shipping would be to delta and get d16a8/a9 pistons(i think)
1990 Honda Civic std - ls swap
1994 Eagle Talon dl - daily driver and slow as balls
I should make a paper mache turbo and manifold.. I shall call it.. the SSAutoMache
Old 02-16-2006, 06:04 PM
Tony's Avatar
TLD Member #1
And after you put those A1 pistons in....go get it tuned because your gonna need it. Those pistons will up your compression big time, and you will need it tuned and on the best pump gas you can get.
Tony
Old 02-16-2006, 06:11 PM
1990civicdxhb's Avatar
1990civicdxhb 1990civicdxhb is offline
well.......
by the mods these guys told you,you should be set & ready to go,lol
gl
In the process of B00stin my D
Old 02-16-2006, 09:11 PM
Kven's Avatar
Originally Posted by duffman868
get some d16a1 pistons and throw them in a d16 block.)
The D15 crankshaft wouldn't work in a D16 block(different journal size); so you would have to use a complete D16 block.
The P29/PM7 pistons with a 2-layer HG will bump your CR to 10:1 though.
btw, to get it tuned means you need to socket your ECU or get a piggyback system.
1988 Honda CRX DX
Old 02-17-2006, 06:35 PM
Tony's Avatar
TLD Member #1
Is it only 10:1 with the P29? All the calculators I have used have read higher than that. Ofcourse I'm working on a z6, thinking of using P29 pistons, and I'm not too sure which caculators to believe, since some give me a reading like 12:1 and then others give me 14:1. I'm hoping just 12:1 because for my purpose, thats pushing it as it is.
Tony
