Old 02-15-2006, 11:24 AM
tomj76 tomj76 is offline
Strut Bearing Problem
'96 Ford Windstar; 3.8L
The "insulator" at top of the spring is not turning smoothly when the vehicle is on the ground. If the vehicle is raised, the movement is smooth. Because the insulator is not turning smooth, the movement is jerky and gives the sound of intermittent grinding.
I have replaced the thrust bearing, but no improvment was seen.
I have inspected the insulator/bearing/mounting bracket and do not see any interference that might cause this. I have also found the the bracket can be turned on the bench (with the help of a wrench) without any jerky movement.
I am at a loss as to what is causing this.
http://www.autozone.com/images/cds/g...3d801d3d1a.gif
Old 02-15-2006, 11:47 AM
Re: Strut Bearing Problem
I forgot to add that this noise is temperature dependent. When the ambient temp is above ~55 F, there is no noise.
Old 02-15-2006, 12:58 PM
12Ounce 12Ounce is offline
The isolator block and the thrust bearing are sold together at Advance Auto.
I have heard of a bit of "sag" in the block allowing the top of the coil spring assembly rubbing the inside of the shock tower. ???
Old 02-15-2006, 01:30 PM
When I purchased the bearing it came with the strut mounting bracket. I tried the strut with the original mounting bracket as well as with the new one, but no difference in the performance.
Regarding the isolator block saging, that was also my suspicion when I inspected the assembly on the bench. The clearance seemed sufficient, several tenths of an inch, but I suppose could replace it. It's hard to tell if there is contact between the block and the strut tower/body. I'll take a look at that to see if there's anything I can see if I specifically look for it. If I remove the strut (yet again), I'd expect to see some marks were there has been contact. I believe the isolator in place is original equipment, although possibly not. A few years back the thrust bearing was replaced due to damage from a pot hole (a relatively fragile design, I've found).
This line of thought has me wondering if the problem could have arisen should the isolator have been rotated to a different position when the bearing was replaced. I maintained it's position when I overhauled the strut assembly.
Thanks for the input.
Old 02-15-2006, 02:30 PM
I wonder if the thrust bearing is not bad. ??? Are you having the exact same results before and after replacing it?
Did you replace the shock unit also? (The shock piston is in a different location in the cylinder when the strut is compressed.)
Old 02-15-2006, 02:49 PM
I replaced the thrust bearing first, but saw no improvement. Then I changed the strut mount, since a new one was included with the bearing.
I have not replaced any other components in the strut assembly. I don't know if you're suggesting a bent strut rod (which is another suspicion that I've considered), but I can't see where that could cause this problem. I could be wrong, and it wouldn't be the first time.
I exercised the strut pistion when I had it dissasembled, but didn't notice any roughness or hang up.
Old 02-15-2006, 05:15 PM
wiswind wiswind is offline
I wonder if the Monroe "quick strut" might be the way to go.
I includes the whole assembly, strut, spring, bearing, etc.
Old 02-15-2006, 06:02 PM
I read about the "quick strut" on the other thread. Of course higher cost for more convience would be the main differentiation issue.
Old 02-15-2006, 11:23 PM
I haven't tried the following, but would if I had your symptoms ... just to make sure the problem is in the upper strut area.
Jack the vehicle up. Disconnect the tie rod. Disconnect the anti-sway bar link. Place a support (scrap wood?) under the lower control arm. Lower the vehicle until the strut is compressed, but the wheel does not touch the ground.
Twist the wheel about to see if you still have the apparent upper strut problem.
Of course, you could also remove the wheel and do the twisting on the rotor. A couple of lug-nuts installed upside down will prevent the rotor from being loose.
Old 02-16-2006, 04:05 PM
Yes, I've done that without the spring compress and it moves smoothly when the steering knuckle is turned back and forth. Also, with everything assemebled and the tire on the ground, I can look up into the strut tower while a helper turns the steering wheel. When I watch the isolator plate, I can see it moving along in this jerky manner.
Old 02-17-2006, 02:07 PM
OK, one more (bad) suggestion:
It'd be a bit of work, but why not swap the strut units left-right. This would prove/disprove that the problem is in the strut itself.
Old 02-20-2006, 09:36 PM
Riordan3 Riordan3 is offline
Well when you find out whats causing this noise for sure let me know. My 1998 Windstar has the same problem and it only seems to do it when the weather gets cold. When warm weather returns the noise is gone. Mine is on the right side ( passengers side ) strut assembly. I had it back to Monroe twice after they had replaced the strut assembly but it has come back after a while. Not sure what they did other than replace the upper strut bearing plate.
Riordan3
1998 Windstar 199K( ex co car now Lowes hauling veh )
2004 Buick Regal 79K (wife's car )
2007 Dodge Grand Caravan 108K(company car )
2007 Mustang GT convertible torch red (my toy)18K
Old 06-16-2007, 04:40 PM
I found out that this is caused by the upper spring seat rubbing on the underside of the shock/strut tower (as suggested above). TSB 02-13-02 recommends installing a spacer above the upper strut mount, below the tower sheet metal. The TSB even mentions the temperature sensitivity that I noticed. The part number of the spacer is 18A027. Thanks 12Ounce for a right on diagnosis.
Old 06-16-2007, 10:08 PM
parkerb parkerb is offline
i can 2nd all this. every time i do strut replacements i have to include the spacer. if i don't, i get the noise while turning. this has happened on my '98, '00 and '02
Old 07-10-2007, 03:59 PM
huskerdooo huskerdooo is offline
Does anyone know if this sound is just an annoyance or does it represent a safety issue? (Does it need to be fixed?)
