Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-15-2006, 05:20 AM
relic12003 relic12003 is offline
Send a message via Yahoo to relic12003
1992 Regal, 3.8 lit. stalled
The car ran great till a couple of days ago. It was idling fine, then just died. It started and ran for a few minutes then died again without warning. I couldn't hear the fuel pump, so i changed that. Still wouldn't start. I hooked in a GM code reader. It showed codes 17, and 66. 16 is for the cam sensor circuit, and ECM. 66 shows the ECM and low refrigerant. I know the refrigerant is low so I just looked at the ECM. I changed the cam sensor, no go, I changed the ECM and no go. I put a crank sensor in her last summer. Can anybody tell me if this is my problem again? At that time she would run for a day... a week.... then die. If anybody can help me I would greatly appreciate it. thank you.
Old 02-16-2006, 11:27 PM
tomogchi tomogchi is offline
Send a message via AIM to tomogchi Send a message via MSN to tomogchi
Re: 1992 Regal, 3.8 lit. stalled
Sounds like an Ignition module problem, or a coil pack problem. or a combination of both. I would Replace the Ignition module or atleast get it tested at your local garage. and then try the packs..... if one or more of the packs is giving out, that could be part of your problem. If you cant get the Icm (ignition control module, commonly refered to as a base plate) tested at a garage, remove the plug wires from one pack, and try to turn over the motor. There should be a Bright blue spark (you will hear it) jump between the 2 terminals of the coil pack. then move onto the next coil pack, and so on and so forth. if they all give spark, i would check the wiring around the engine. Or even... Possibily the crank sensor moved out of position,a nd you might jsut have to re-align it. It could be that simple. Because a hard code for a crank sensor, will make the vehicle not run. a cam sensor, will make the vehicle run in sequental firing mode (the last known good configuration that the ecm remembers), but will not cause a vehicle to not run.
Good luck,
Bill
