Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 02-15-2006, 03:03 AM
Ragai Ragai is offline
OBD or OBD II
Hello,
I have 1989 Ninety Eight Regency. I need to know which OBD it is equiped with so I can buy the proper code reader. Any help is appreciated.
Old 02-15-2006, 07:16 AM
fourtwenty fourtwenty is offline
Re: OBD or OBD II
Try google. It's amazing what you can find.
http://www.google.ca/search?hl=en&q=...cy++OBD+&meta=
Old 02-15-2006, 07:31 AM
maxwedge maxwedge is offline
A990 racer
Re: OBD or OBD II
6 years before obd11, it's obd 1.
Old 02-17-2006, 09:42 PM
niemo810 niemo810 is offline
Send a message via AIM to niemo810
Re: OBD or OBD II
i have a 94 LSS 3.8L blah blah blah...
not sure which system my car has (or is supposed to)
obd-II scanner reads "failed" when tested.
doesn't have a 'pin-b' like all the obd-I systems.
has the rounded connector like the obd-II system.
why would the obd-II scanner say "failed" if it's an obd-II system?
Old 02-18-2006, 01:23 PM
A990 racer
Re: OBD or OBD II
Not all scanners have the proper cable set up for that transitional year.
Old 02-18-2006, 10:18 PM
Re: OBD or OBD II
where could i buy or use a scanner with those capabilities?
Old 02-19-2006, 09:52 AM
A990 racer
Re: OBD or OBD II
For personal use, Actron 9145 should work, check their website
Old 02-19-2006, 12:22 PM
Re: OBD or OBD II
thanks for the reply. had no idea there were so many complications in the transitional years. you're right, the 9145 will work. thanks again.
Old 02-24-2006, 12:47 AM
Hansnet's Avatar
Hansnet Hansnet is offline
Re: OBD or OBD II
you have a hybrid obd 1.5
actron cp9145 or whatever will read it
