trans help
dont really want to post this here but i need help lilke really, really fast. i just got done putting a junkyard tranny in a 96 ford van, now it drives but it wont shift out of 1st, what could be the prob besides a bad tranny??
and yes I KNOW this isnt the right forum, but what other forum has this much activity?
![]() Teamsters Local 332 1998 GMC Jimmy, 4.3 Vortec V6, 80,000 Miles, K&N Filter 1992 Chevrolet Camaro RS, 355 TPI, Under Construction |
Re: trans help
did you change the tranny fluid before you put it in the car? the clutch packs might be shot since you got out of a junkyard... also you could try adjusting the linkage, it may only be putting the tranny into first when you put it into drive... does reverse work?
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune. |
Re: trans help
torque converter might be shot... thats usually what happens when it goes (if its internal)
![]() 1995 Camaro - Z28 - M6 - Hardtop 2007 GMC Sierra 2500HD SLT Classic -R.I.P. Andy (Hypsi)- |
