Old 02-14-2006, 11:48 PM
dustinlmiller13 dustinlmiller13 is offline
Question Small Block Cylinder Heads
I have a 1980 model Camaro with a 1974 carb 350 with headers, glasspacks, edelbrock intake, etc. I recently found the option to buy a set of stock remanufactured heads from an Advance Auto Parts store and was wondering if anyone else has went this route and were they impressed with the quality of the product? Thank you for your replies. I am buying rather soon and have limited funds. The old heads are smog stock and I was going to buy 327 heads to up my compression a little.
Old 02-14-2006, 11:53 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Re: Small Block Cylinder Heads
get them re worked, or buy performance onces. The stock one suck. I would get your re worked, probly cheeper to.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-15-2006, 12:05 AM
The old smog type heads had even less performance than some of the 69 350's or 327's stock.
Anything is possible through Christ our Lord.
1980 Camaro: Base coupe sleeper with 350 4bolt main (stock bore, double humps, 480 lunati cam, flowtech headers). Stock 2.73 open rear (changing next month to 4.10 mini spool).
Old 02-15-2006, 12:08 AM
97cavalier's Avatar
I would go to a junk yard and pick some up and get them reworked, or get yours reworked.
Old 03-07-2006, 10:21 PM
blownz2886 blownz2886 is offline
Just an idea, my buddy has a very mild built 350 in his 85 camaro. He used a set of 305HO heads with a flat top piston. Has a mild r.v. style cam. Makes pretty impressive low end and mid range power up to about 6000. This is a reativley cheap way to increase compression and make decent power on a tight budget. Heres my 383 stroker w/ Dyers 671 street charger, built by Rodlands Crank Grinding and Automotive Machine. www.performancecncblocks.com
Old 03-08-2006, 09:20 PM
TLBLZER TLBLZER is offline
I also have seen this done to get more compression. My friend has been the over all winner at the dirt tracks for 4 years and running and he told me that 305 heads were the trick.
Old 03-09-2006, 03:46 AM
Morley Morley is offline
Keep an eye out on E bay for Corvette aluminum 113 heads. they have 58cc chambers like the 305 heads but are made for a 350. They usually go for around $300 or so.
Old 03-09-2006, 08:44 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
even a set of vortec heads would be a good idea.
Old 03-09-2006, 09:40 PM
97cavalier's Avatar
the vortec heads have more compression also.
Old 04-03-2006, 10:19 AM
demon9766 demon9766 is offline
Send a message via Yahoo to demon9766
I would just buy a set of aftermarket heads they cost a little more but they will be good to go. I got AFR myself and they work great.
This is what 500 plus hp looks like.CNC ported AFRHEADS WITH 2.02 INT 1.60EXH,210 intake runners 74cc chambers, 750 speed demon carb,weiand intake,comp cams 292 with .501/.501 lift ,4340 forged crank,eagle H-beam rods duroshield bearings,KB forged 10 1/2:1 pistons,headers with 1 3/4 primaries ,MSD 6AL,comp cams pro mag1.6 rockers,holley blue pro-series pumps,MSD billet distributor.All stuffed into a 355.[img][/img]
Old 04-03-2006, 11:32 AM
Genopsyde's Avatar
The President
AFR's are great, but damn expensive.
