Go Back   Automotive Forums Car Chat > Chrysler > Lebaron
Old 02-14-2006, 10:47 PM
EnergyForce EnergyForce is offline
Timing System Question
Hi everybody I have a question about my timing system specifically wether or not the timing is controlled by a belt or chains. I have a 1993 Chyrsler Lebaron 4 door sedan 6cyl 3.0L engine. I asked about replacing the belt/chain and the rather high cost suggested to me that it would be chains rather than a belt.
Old 02-16-2006, 07:52 PM
ur8n ur8n is offline
Re: Timing System Question
you have a belt and should be able to get it at an auto parts store for $50
Old 02-16-2006, 11:35 PM
K thanks for info, its just when the repair shop said it was going to cost like $500 I was like and
Old 03-13-2006, 02:36 PM
Boogieman142 Boogieman142 is offline
Send a message via AIM to Boogieman142 Send a message via MSN to Boogieman142 Send a message via Yahoo to Boogieman142
well, a lot of that cost is labor, also while you are in there change the waterpump, the crank and cam seals too, also, it might not be a bad idea to change the tensioner.
Old 03-16-2006, 01:26 PM
ugh that sounds even more expensive. <sighs> I wonder if there is anyway they can just take a look at it without having to spend $500 it looks like there is a panel on the engine that would come off easy to check the belt.
