Old 02-14-2006, 09:42 PM
Bob1942 Bob1942 is offline
Camaro Valve Seals Question 305 V-8
I am rebuilding a 305 -1991 Camaro roller cam engine . I got new original type valve seals for it in a plastic bag with NO instructions ...The seals I got come with 32 little black O-rings that is 2 for each valve ! ...Where do these go ? UNDER the seals ? Over the seals ? or where ? I want to get these in there correctly ... Thanks guys ! Retired Bob still turnin wrenches !
Old 02-15-2006, 09:34 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Camaro Valve Seals Question 305 V-8
If the seal is an O-ring type, it is installed just after compressing the spring but before the valve locks.
Old 02-15-2006, 09:38 AM
Link85x Link85x is offline
Wrightz28, could you list all of the gaskets i would need to replace when i do my cam swap. Timing cover, thermo, valve cover, runners? upper and lower plenum? What else? I'm getting some valve seals aswell.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
Old 02-15-2006, 09:46 AM
wrightz28's Avatar
You pretty well nailed it, except the water pump and T/B.
if it were me, I'd just get a complete engine gasket set, that way you have all of the ones you need, including the ones you forget and the ones you may not use now, but probably will later.
Question for you, do you have access to a lathe? There's a neat trick with the cam sprocket that really wakes the motor up.
****Oh, also since you're pulling the radiator, now would be a good time to replace ALL the hoses, upper,lower, heater, trans, etc.
Old 02-15-2006, 10:04 AM
Where can i get an engine gasket set from? Also, what is lathe?
Old 02-15-2006, 10:39 AM
wrightz28's Avatar
"Where can i get an engine gasket set from? "
anywhere that sells parts.
"Also, what is lathe?"
Nevermind
Old 02-15-2006, 10:50 AM
HAHAHAHAHA!!!! I knew they were dumb questions.
