Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 02-14-2006, 08:29 PM
Gary52 Gary52 is offline
92 grand marquis auto lamp problems
I have a 92 Grand marquis. The other night when auto lamps turned on I noticed there were no dash lamps. I pulled over and there were no tailamps or licence lamps also. When I turned lights on manually everything worked. All fuses seem to be OK. I am wondering if it could be a relay. I checked at Ford dealer and relay is obsolete and their diagram showed it behind RH side of dash. Has any-one experienced this problem. Thanks
Old 02-15-2006, 05:09 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
Re: 92 grand marquis auto lamp problems
i to have a 1992 gm LS and have never had this problem if i were u i would try to get a new or slightly used relay but none the less good luck and for now i would just use the lights manually
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-15-2006, 11:04 PM
Stevo2's Avatar
Stevo2 Stevo2 is offline
My info says this for a location...
Behind LH Side Of I/P, Above Steering Column
The pic shows it just to the right of the steering column. DUH?!?!
I'm not real sure what it is supposed to look like but here we go anyway. I believe the ford part# is F1DZ13A025A..this is for the Sentinal Relay. this part number crosses over to NAPA# ECHAR650. Should look like this?
Jack of all trades...Master of none!
Could someone please fix my Instant Email Notification?
Please get back to us with your fix!
Why did you buy a $40K vehicle and not a $100 Factory Service Manual?
