Go Back   Automotive Forums Car Chat > Ford > ZX2
Old 02-14-2006, 06:20 PM
Wormzer410 Wormzer410 is offline
ZX2 Engine Replacement
I have a '98 ZX2 and the engine is shot. I looking to pick up another angine to put in. Question is will a Zetec engine out of a Contour or Focus work in a ZX2? I've had a couple people tell me that I have to get an engine out of another ZX2. Any advise??
Old 02-14-2006, 06:45 PM
AltecZX2 AltecZX2 is offline
Send a message via MSN to AltecZX2
Re: ZX2 Engine Replacement
they will...but it will be a LOT of rewireing (the focus does not have VCT either, bebending on the contour it might or may not)
For the focus motor you also need to move a motor mount(not sure about the contour)
for a 98 ZX2 you need to use a 98-early 99 zx2 motor(small wiring difference) you can use a 99.5+ but im not 100% on how much difference the wireing change is...i believe it mostly just a CCRM change and a small rewire.
What do you mean by "shot"?
FORMERLY: zx2srdotnet(1,380 posts)
2001 Esxort ZX2 - Traded
2000 Escort ZX2 S/R - Sold
2003 Mustang Mach1 - Totaled
2014 Altima 2.5 S - Purchasing Soon
Old 02-15-2006, 09:45 AM
The timing belt broke and took out the valves and possibly the piston on the fourth cylinder. The engine can be fixxed, but I'm looking at close to $2,000 to have it repaired. I'm just looking for other ideas to fix the car that might be a little cheaper.
Old 02-15-2006, 10:49 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
zetec is non-interference, you did NOT bend any valve, retime your motor and put a new belt on and it's good as new
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 02-15-2006, 10:52 AM
unless you running a very agressive cam..you didnt bend anything.
Old 02-15-2006, 11:10 AM
I had a new timing belt installed and and had it timed and now the car has no compression in the fourth cylinder. Any ideas what else it could be?
Old 02-15-2006, 01:25 PM
mtmaurer8ooo mtmaurer8ooo is offline
I'M PUTTING THIS IN ALL CAPS SO EVERYONE WILL SEE IT.
BEFORE YOU DO ANYTHING GO TO THIS SITE AND SEE WHAT THEY CAN DO FOR YOU!
-- http://cherry-auto.proxsoft.com --
THEY HAVE THE BEST PRICING I HAVE SEEN ANYWHERE.
YOU DON'T HAVE TO SIGN IN TO SEARCH, JUST SEARCH.
Old 02-15-2006, 02:28 PM
there is a motor on ebay right now
Old 02-16-2006, 04:52 PM
Let's see.......um, head gasket??? Ring job??? Timing issues??? Could be a lot of things. Sound like you need to have someone look into it.
