D16Z6 Swap
I have a stock d15b2 engine in DPFI so if i want to do a d16z6 swap what all things would i need. What if i get a d16z6 engine harness and interior harness and d16z6 ecu or what ever runs this engine the best then what would i have to get beside the engine. Would i need a new cluster. Or what year modle did this engine come in a car so i can look for a interior harness on Ebay.
Re: D16Z6 Swap
It would basically be like this:
http://www.efsource.net/D15BHT/D15BVTECSwap.html Few exceptions are youd have to wire MPFI... I think its eaiser to do that, or get a rywire DX to VTEC harness than to use a Civic harness... |
Re: D16Z6 Swap
the car that the d16z6 came in will not match the interior harness for your car, it will all be obd-1, and also from another car...Youll need to swap to mpfi, or get a civic ex interior and engine harness, then wire vtec.
Cheap, Fast, Reliable..Pick two ![]() Current project: Rio Red 91 hatch. A6/Z6 build, Hondata S300, Tokico illumina/Ground Control. "I'd rather run 12's on steelies than 15's on rotas." |
Re: D16Z6 Swap
What the easyest way to do the swap.
Re: D16Z6 Swap
The Easiest...do some searching, there are plenty of how-tos and walk throughs on doing the MPFI swap and a Z6 swap. The easiest would be do the MPFI swap, use a D16A6 computer(88-91 Si), along with a D16A6 distributor. Swap out motors and do any necessary wire changes and add the VTEC. The Z6 came in the 92-95 Civic and Del Sols. Im unsure on exact models.
Trust me, you don't want to swap out entire harnesses, its a lot more work than you really want.
Tony 91 Civic Sedan DX - Stock 287k Miles |
Re: D16Z6 Swap
Well what about swaping from d15b2 to d15b vtec will i still have to switch from DPFI to MPFI and get engine harnesses and everything like that. Also would a d15b vetc bolt right up into my engine bay with the stock mounts or would i have to change them?
Re: D16Z6 Swap
if you want it to be worth while I really suggest getting p28 ecu and buying an obd-0 to obd-1 harness and going to MPFI, since DPFI sucks...
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh |
Re: D16Z6 Swap
With any swap youll need (well technically u wont HAVE too, ill explain later) to switch from DPFI to MPFI since all other performance engines are MPFI... I say you dont HAVE to because the DPFI manifold will bolt to most of the other D series engines, but it will not be sufficient enough to supply the engine with enough a/f to make a difference... So it wouldnt even be worth it... The D15B VTEC will bolt right onto your cable tranny (tho since u have a DX Id reccomend an Si tranny for better performance), which has 3 of the 4 stock mounts on it, as for the 4th (drivers side mount) youll have to pull the bracket (the peice that bolts onto your engine block under the timing cover) from your stock engine and use your stock mount... So in short, yes u retain your stock mounts... You cannot however, use the hydraulic tranny that comes with the engine with out more work, so I dont even reccomend buying it... Just get the cable Civic/CRX Si tranny its got better gearing anyways... |
Re: D16Z6 Swap
Well the engine dosnt come with the tranny,altinato,or a/c compressor. But can i use all that off my d15b2 that i have? As for the transsmission i can ust the d15b2 stock one until i can get a SI tranny, right? Then i have to do a DPFI to MPFi and obd0 to obd1, Just trying to make sure i got a these things right. Also would this tranny fit the D15B VTEC
http://cgi.ebay.com/ebaymotors/88-89...spagenameZWDVW |
Re: D16Z6 Swap
Haha, I saw that posted on a local forum I visit... I guess he couldnt sell it locally so he listed it... Anyways, yes, the A/C, alt, and all that will swap over from your stock engine... The only difference, which dosnt really matter, is the newer alternators have a 3 ribbed belt, so that means the crank pulley will have a 3 ribbed space for that alternator, but I used my stock 2 ribbed alternator and belt on the 3 ribbed crank pulley and it works fine, its just got an extra rim there is all... As for the tranny, yea your stock tranny will work fine until you can buy an Si tranny...
Re: D16Z6 Swap
Well im going to try this i got plenty of time do do the swap so i want be in a hurry and mess something up im gonna take my time and do it right.
Re: D16Z6 Swap
Good luck! I always like to see people take interest in their vehicles and how they work, and want to make them better.
Re: D16Z6 Swap
Well yep thats all me i have had plenty of offers to sell my car but i just love it to much.
Re: D16Z6 Swap
Me too, this baby is gonna be mine for a long time.....
Re: D16Z6 Swap
Did you do your swap yourself? Or did you get someone to help you.
