timing
1995 GMC YUKON
my problem is setting the timing after i r/r the intake gasket .now the dist rotor is set about 45degrees away from tdc i set the crank pullet at TDC and got the blow out from my #1 cylinder but im still 45degrees off (about)a mechanic told me to take the distributer out and stick a long screwdriver down the shaft and rotate the shaft for the distributer but i cant get it to move much more and it's still off a very little.I'm getting very frustrated can you walk me through it ,anyone? Sonny. |
Re: timing
Look at this article: http://www.chevyhiperformance.com/ho...673/index.html
Scroll down and look for "if the engine was disturbed" and read on from there. //2000CAYukon |
Re: timing
thank you for your reply to my posting ,unfortonently my other mechanic came last night and set the timing for me .it looks like i may have damaged a lifter possibly a vave ,but not likely .I'm on my way out to do a compresson test now.thanks again,SONNY.
