Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-14-2006, 03:04 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
Filter Size On Gsx
I have a K and N filter right now and it has a 4" inlet which is connected to the metal adapter... I need a new filter because mine is worn pretty bad but will getting a different cone filter with a different adapter and a smaller 3" inlet be worse for the performance due to the smaller size of the inlet?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 02-14-2006, 03:05 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Re: Filter Size On Gsx
Why would you get a smaller filter? Just get the same size that you have on it.
95 Talon TSI AWD
97 Eclipse GST
Old 02-14-2006, 03:28 PM
yea but would that affect performance?
SOLD
'97 GSX
Old 02-14-2006, 03:32 PM
I wouldn't think so, not anything noticeable anyways. A 3" intake is still alot of air intake.
95 Talon TSI AWD
97 Eclipse GST
Old 02-14-2006, 03:39 PM
The one i had came with the injen pipe and was also injen... its more like a 4.5" inlet when i measured it so..
SOLD
'97 GSX
Old 02-14-2006, 05:31 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
The bigger the better. Stick with what you have.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 02-14-2006, 06:33 PM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
if u can find the filter again stick with it
O/T 100 posts to go WAHOOOOOOO!!!!!!!!!!
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-14-2006, 07:39 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
Intake Filter designe and size both effect the performance of an engine. I'll find the equation.....
DSM geek
Old 02-14-2006, 07:50 PM
Below is a series of formulas to determine air filter size for a given air flow capacity
1: Square inches of filter required for a motor = CID x Maximum RPM / 20839
2: CFM required for a 4 stroke motor = CID x Maximum RPM / 3456
3: CFM required for a 2 stroke motor = CID x Maximum RPM / 1728
4: CFM required for a turbocharged or supercharged motor = Pounds of Boost / 14.7..
Add 1.0 to this answer. This relates to #2 and #3
Example: (CID x maximum RPM x #4 ) / 3456 or 1728
5: To find circumference of a circle multiply diameter by 3.1416
6: To find diameter of a circle multiply circumference by .31831
Round: Diameter x Height x 6 x 3.14
Flat Panel: Length x Width x 6
Universal Round Taper: (Base + Top) / 2 = A
Take A x Length x 6 x 3.14
Universal Round Straight: Diameter x Length x 6 x 3.14
Hope that helps.
DSM geek
Old 02-15-2006, 08:31 AM
TheRomer TheRomer is offline
..... umm yea i would just get the biggest one you can fit. i dont like doing math personaly.
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
Old 02-15-2006, 03:40 PM
What size is the filter that comes with the injen intake?
I measured and its like 4.5" for the inlet but i dont know does anyone have a link to one that would replace it using the metal adapter that came with it?
SOLD
'97 GSX
Old 02-15-2006, 04:44 PM
RIDER...if you could get us some pictures it would help out alot.
95 Talon TSI AWD
97 Eclipse GST
Old 02-15-2006, 10:16 PM
EricSchnabel EricSchnabel is offline
Bigger is always better or at least for a car anyways
Old 02-15-2006, 11:05 PM
Thats why you'll probably flunk out of school. I don't know why I even try some times.
DSM geek
Old 02-15-2006, 11:28 PM
xavier3jr's Avatar
lmao math is so easy...i dont see why people dont get it..
