Old 02-14-2006, 01:18 PM
stc78 stc78 is offline
Question 88 camaro engine swap v6 to tpi 305
allright fellas im doing an engine swap on a 88 camaro it originall had a v6 stick long gone when i got it, and i found a donor 86 trans am 305 tpi auto 700r4, ive taken the motor and trans out and are in the camaro, i took the complete harness from the t/a and pcm i mean every thing right to the light harness, now my question is i know im gona have to splice the light harness from the camaro to the t/a harness 2 head lamps, no problem. what im wondering is if i bolt the harrness to the firewall will it match up and run, is there fuses i have to put in the box for the extra circuts, i know an 88 camaro cold have been ordered with a 305 tpi, and they wire for all options right? the cars are only 2 years different, i guess im asking if anyone has had experience with this before come on guys your knowledge is vast and im sure its not an uncomon swap right?
thanks fellas i await your knowledge
Old 02-14-2006, 03:59 PM
instantkevin's Avatar
instantkevin instantkevin is offline
Send a message via Yahoo to instantkevin
Re: 88 camaro engine swap v6 to tpi 305
I would assume they put the same wiring in all of them. but, you should just be able to compare the two different boxes and see the differences if there are any.
90 Camaro RS V6 - swapped to V8
-350 block, GM Vortec L31 Heads, Edelbrock Performer RPM Vortec intake, 750cfm carb, CompCams XE268 Camshaft
ESTIMATED 360-420 hp 380-430lb/ft torque
Old 02-15-2006, 12:13 AM
yea im gona lay it out this weekend and see what ive got, but if any one has got experience in this please let me know thanks a lot guys
