Go Back   Automotive Forums Car Chat > Jeep > Wrangler
Old 02-14-2006, 10:43 AM
Kuhn's Avatar
Kuhn Kuhn is offline
Send a message via AIM to Kuhn Send a message via Yahoo to Kuhn
Vibration While Accelerating
I've got about a 3.5'' to 4'' suspension lift and I'm pretty sure the drive shaft is stock. ( I bought this used with the work already done.) I want to lift this about 2'' or 3'' more so I can fit 35s, but I want to fix some issues first that I think have to do with thte lift. There is a slight vibration/hop when accelerating and it's a little difficult to shift into 2nd and Reverse. What could fix this and prepare me for a 1'' or 2'' BL and 2'' coil spacers? I'm thinking I need to drop the transfer case, but how far? Do I need a longer driveshaft as well? I'm sure the answer is somewhere on this forum, but I can't find it exactly. So please supply a link if anybody finds something. Thanks
'98 Eclipse RS
ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now).
SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere.
Old 02-28-2006, 12:45 PM
ffgoody ffgoody is offline
Re: Vibration While Accelerating
i had vibration when accelerating in the begining of first gear with just a 2.5" shackle lift and stock 30's. usually doing anything (besides a body lift) to fit 33's is going to require a slip yoke eliminator and an upgraded cv driveshaft. these can be somewhat expensive but worth the investment, this will help cut down on wear and tear on both your tranny and diff and will alloy you to flex to your full capability. as for dropping the t case, usually this is done when working towords 38's, and after the sye and cv upgrades have already been installed
