Go Back   Automotive Forums Car Chat > Daewoo > Lanos | Kalos
Old 02-14-2006, 07:03 AM
LJT94 LJT94 is offline
Foggy Windows
can anyone help, i've got a 1999 lanos 1.4, that constantly has fogged up windows on the inside, it happens most days, even if i haven't been in car all day.
Old 02-14-2006, 01:38 PM
MeettheCreeper's Avatar
MeettheCreeper MeettheCreeper is offline
Re: Foggy Windows
That may be an indication that the heater core is leaking.
Old 03-14-2006, 04:50 AM
Joihan777's Avatar
Joihan777 Joihan777 is offline
Unhappy Re: Foggy Windows
Are you correctly using the defogger?
Try to use the fresh air instead of the recycled air.
Are you a smoker? Water vapor catches on to smoke particulates
stuck to the inside of your glass thus fogging up quickly.
Also, is your dehumidifier tube plugged? (Does a little water drip
down from under your engine area when A/C on? This is normal!)
If you smell sweet air and foggy, then yup your heater core is leaking.
Or at least a tube to it.
G/Luck
johann
"Little Blue War Pony!!"-2002 Isuzu Rodeo Sport Sparkly-Blue 3.2v6 2wd softtop....0-60 8.0secs =)
