Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-14-2006, 01:52 AM
brattzzzzz brattzzzzz is offline
96 Eclipse not starting
Hi i was using my eclipse non turbo and it just died on me
i tryed to jump it with jumper cables and it would not jump
i can hear the starter trying to start the car but it just wont start?
does anyone have any suggestions?
Old 02-14-2006, 02:29 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: 96 Eclipse not starting
Have you checked your spark splugs and wires? Coil pack? Make sure it still geting fuel?
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 02-14-2006, 03:09 AM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
Have you been having any problems with the car lately? When you say you can hear the starter trying to start it do you mean that you can hear just the starter going but the car will not turn over, or the car turns over and will not start up? Like xavier said, you need fuel, spark, and air for a car to run. Make sure you're getting fuel to the cylinders and also make sure you're getting spark at the end of the spark plugs. If you're getting both fuel and spark, it's time for a compression test but a car wouldn't just die because of a loss of compression unless you lost timing.
95 Talon TSI AWD
97 Eclipse GST
Old 02-14-2006, 09:45 PM
if the alternator is dead would that cause the car not to start?
i thought if i jump start it that it would turn over
the battery is dead no juice!
the spark plugs look pretty bad
it starts when i put the jumper cables on but it will not continue running
Old 02-14-2006, 09:46 PM
yes the engine turns over the starter is working
Old 02-14-2006, 09:53 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
First off... I do not think a dead alternator would prevent your car from starting however it would drain your battery(dead battery = no start). You might want to get new plugs(if they look bad) and probably an alternator. However, I am not a mechanic just my Lastley, I'm not trying to be the ass here but, this post should be in Problem Diagnosis not Performance.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 02-15-2006, 02:42 AM
Get new plug wires if they look bad, pull the plugs and replace those too while you're at it. A dead alternator wouldn't have anything to do with the car not starting if you charge the battery. If the battery is old, replace it with a new one as it likely won't hold a charge anymore. Then if it dies while running, time for a new alternator.
95 Talon TSI AWD
97 Eclipse GST
Old 02-15-2006, 02:56 AM
xavier3jr's Avatar
if u can hear the motor trying to turn over its more then likely not your batter id still stay on the lines of ignition sequence.
Old 02-15-2006, 03:53 AM
It turns over when he connects jumper cables and then quits when he disconnects them.
95 Talon TSI AWD
97 Eclipse GST
Old 02-15-2006, 03:59 AM
xavier3jr's Avatar
oh i didnt see that im sorry yes definatly change your bettery and see if it will start then if it is the battery that came with the car in 96 its more then likely deader then hell
Old 02-15-2006, 08:26 AM
TheRomer TheRomer is offline
mine did the same thing when i was switching garages... are the terminals tight on ur battery? the positive one was loose on mine and it jumped fine then when the cables came off it died. try tightening them, and if that doesnt work, like everyone else said its probably the battery.
Chris Winchell
95 GSX 12.5 ET with a 1.9 60' at 115 mph
Actually have traction this year
90 TSI <Project Acer>
2.0L, 2400 lbs AWD, t-67 goodness
