2000 windstar headlights come back on
i just bought this a week ago and all the sudden the dome lights would stay on . i think that slide switch is bad i can unplug it and slide it up and down then plug it back in ,it works ..now when i turn it off about five seconds later the lights ( front and rear) head and tail come back on ?i have no idea what is causing it . #16 fuse keeps blowing as soon as i put it back in #10 was blown replaced it .it is ok but now no gauges at all . any help would be appreciated .
Re: 2000 windstar headlights come back on
Are you asking about headlights or dome lights? The dome light problem is common with Ford products. Do a search in the Windstar forum for "dome light" and you'll see a bunch of threads pertaining to this. A tip if you have a fuse blow right when it's put in. Solder wires on to a tail light bulb. Put the bulb in place of the fuse. Start pulling parts that are powered by the fuse (bulb) until the bulb goes out. When the bulb goes out you've found the short. Regards Dan
******************************************* Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK Photos of my repairs: http://dansautopictures.shutterfly.com/ Check this out:http://threewheelmotorcyclemetro.shutterfly.co A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854 95 Windstar 240,000+ 98 Windstar 136,000+ 09-25-2008. 85 Dodge 1 Ton Snow mover gas hog 91 Mazda Protege free beater SW MN |
the headlights were coming on with out the key being in the vehicle.i also lost all gauges.there was a wire from the aftermarket radio touching metal , recrimped all radio wires and then tapped them .now everything is working.except the dome lights they like to stay on . ive read the posts on this matter and i will try it tonight or tomorrow .already have a headache over this ,but thank you for your help .
ok new problem dash lights are staying on and dome could this be one of those famouse door switches?
got the dome lights working but the only way to shut off the dash lights is to pull #16 fuse , i am so lost with this i own two other fords and have not had one fourth the problem with either for 5 years .any help is greatly appreciated
Regards Dan
i unplugged the wires connected to the sliding dimmer and the dash lights stay on ,i unpluged headlight switch and the same results .
Regards Dan
i pulled them out one by one no change in dashlights , but guess what headlights are back on when you turn the key off ..
