Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-13-2006, 11:41 PM
Zebisko Zebisko is offline
Send a message via AIM to Zebisko
'94 Caprice Classic dies when warm
Hello, I was looking at this ad on the internet and it says,
"DOES NOT RUN
Broken ignition switch mechanicals.
Before that it had trouble running. Would run perfect until warm then
die like a switch had been hit. Would crank but not start until cold.
Would restart and run perfect until warm... Did this dozens of times.
No idea whats was wrong. Suspect computer.
Maroon inside and out. Best offer takes. 350 cid"
Now I was wondering what the problem could be, any ideas? Thanks.
Old 02-14-2006, 09:29 PM
96capricemgr 96capricemgr is offline
Re: '94 Caprice Classic dies when warm
Bet the computer is fine, sounds to me more like sensor issues or I have heard of a freak case where the CCP system was screwed up and fresh air couldn't get into the tank and as fuel was burned vacuum built and it would overpower the pump and "ran out of gas" till enough air leaked into the tank to allow the pump to pressurize the system again.
Old 02-16-2006, 10:46 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
Most of the ones I've dealt with had bad ECMs. The electric control module is located on the distributor plate and is easy to change, runs about $40. If it is bad, you will have a no-spark condition at the spark plugs. When it happens, take off one plug wire, stick a screw driver into the wire end, ground it to the engine. Have someone turn the engine over, you should see a fat blue spark jump between the engine & screw driver. If not, I'd suspect the ECM is bad.
Bob
Old 02-16-2006, 09:48 PM
Bob
Sounds like you missed the part where it is a 94, which does not have a Ecm but rather a very reliable Pcm, or the spark module where you are stating since it has an opti the spark module is bolted to the front of the drivers side head.
Old 02-17-2006, 10:09 AM
bobss396's Avatar
Sorry boys & girls, I guess I missed the year and should really stick to the pre-1991 cars that I'm more familiar with, hope no one tried to access or remove a part that is not there!
Bob
