Old 02-13-2006, 10:15 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Headers
How hard is it to put headers on a 92 camaro rs with a 305 tbi? And i am getting full length headers. Can i still pass emissions with out the air line hooked up to the headers? I am getting a set of new headers i think by headmann for $136 out jegs.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 02-13-2006, 10:44 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: Headers
headers are a bitch with the engine still in the car, and from what i've heard you can still pass emmissions without the A.I.R. hooked up.
Old 02-13-2006, 10:47 PM
97cavalier's Avatar
Re: Headers
thats nice to hear,lol. i have a job to look forward to then. Has any body actuly did them on a 305 like mine? Any tips?
Old 02-13-2006, 10:54 PM
Genopsyde's Avatar
The President
Re: Headers
a few ppl have, hopefully they'll spot this thread and fill you in.
Old 02-13-2006, 11:16 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
Re: Headers
I put headers on, they're not impossible but they will take you at least a couple days, unless you work nonstop from sun up to sun down. I would recomend it, makes your 305 sound like a 350
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 02-13-2006, 11:47 PM
Nate355RS's Avatar
Re: Headers
Also before I go to bed, your problem areas are going to be getting the bolts on the passenger side, and making the driver side header fit. I had to take the driverside valve cover off and disconnect the steering shaft or column or whatever you call it, although I probably didn't have to do the last part. If you get those headers and have trouble let me know and I'll try to help you out. Also if keep your AC you might have a little trouble getting around it, but it's not that tough. If you've got determination, you've got all the skills you need.
Old 02-14-2006, 07:24 AM
SG007's Avatar
SG007 SG007 is offline
Send a message via AIM to SG007
Re: Headers
Long tubes scrape on 3rd gens, don't they?
-2000 LS1 Z28-1979 Berlinetta*sold*-1992 RS 25th Anniv. 350*sold*-
Old 02-14-2006, 08:20 PM
97cavalier's Avatar
Re: Headers
on the stock manifolds, are they welded on or clamped to the exhaust pipes?
Old 02-14-2006, 09:54 PM
Nate355RS's Avatar
Re: Headers
They have a flange that connects them to the exaust pipes so you can just unbolt them.
Old 02-14-2006, 10:01 PM
97cavalier's Avatar
Re: Headers
hey nate, do you like your headers? cuz i think i am looking at the same ones you hace, they are made by hedman and i am getting them from jegs for $136 I was wondering how they are.
Old 02-14-2006, 10:19 PM
Nate355RS's Avatar
Re: Headers
I love them, it totally changed the the sound of my car. The only draw back is that I cheaped out on the gaskets and now I've got a leak. One thing that shocked me was how much more of the engine I could hear from behind the wheel, it really increases the noise on the inside when you get on it. I got #500-68471, I think the only differance is that mine are shorties and have a y-pipe.
Old 02-14-2006, 10:25 PM
97cavalier's Avatar
Re: Headers
so should i got with a metal gasket then?
Old 02-14-2006, 10:30 PM
97cavalier's Avatar
Re: Headers
and what is the diffrence between shorites? beshides they are shorter and cheeper? and the only reason i won't get them is because i have to get them welded on, and i don't want any thing burnt under there.
Old 02-14-2006, 10:36 PM
Nate355RS's Avatar
Re: Headers
I've never delt with longtubes so I'm not entirely sure. Do you mean you would have to have to shorties welded or the full length's welded? The shorties, from hedman at least, are stock replacements meaning you can reuse the stock pipes by just bolting them back up or you can get the ones with the stock collector and just clamp them down.
Old 02-14-2006, 10:40 PM
97cavalier's Avatar
Re: Headers
ya, i want a bolt on, i don't want to weld, so the shorties will bolt right up? and i thought where the clamp was farther down, that is why i was looking at long ones.
