Wheels for a 86 Camaro
Im trying to help my 17 old son with his camaro. Hes found a set of after market wheels which are the proper bolt pattern and they are 16 inch. The question I have what is the proper backspacing needed to make these wheels work and what size tires would work for them? I know the front and the rear backspacing is different or am I mis informed? I forgot to mention the wheels are 16 x 8.
Thanks for any and all help. |
Re: Wheels for a 86 Camaro
the offset for stock rims is 0mm. you can use spacers to use rims with more offset. how wide are the rims?
![]() Quote:
They are 16 x 8 wide
then 245 is the widest you can go safely. 225 is the smallest.
![]() Quote:
16x8 is the stock wheel size for my 91 RS
what should the offset be from the back of the hub to the inner lip of the rim I just want to make sure these wheels are going to fit the way they are suppose to fit.
