Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 02-13-2006, 06:10 PM
sreilly77's Avatar
sreilly77 sreilly77 is offline
engine takes almost 8 seconds of cranking beofre it turns over
ok i just had my fuel pump replaced by my mechanic on my 95 town car (kind of hard to do it myself with a foot of snow on the ground haha). the only one was completely shot. here is what is confusing me. after starting the car and having it run for whatever length of time, i can shut it of and then start it right back up again without any problems. however, even if i just let the car sit for like two minutes, ill go back outside, turn the key, and the car will crank between 5 to 8 seconds before the engine finally turns over. im worried because if i let this go over a period of time, my starter will burn out. what is going on here?
Old 02-13-2006, 06:43 PM
sreilly77's Avatar
Re: engine takes almost 8 seconds of cranking beofre it turns over
sorry i definitely can't type, i meant to say the OLD fuel pump not ONLY fuel pump. but i should also mention that it doesnt matter if the car is hot or cold. if you let it sit for even like a minute, it will take almost 10 seconds before the engine turns over.
Old 02-13-2006, 07:29 PM
master hec0's Avatar
master hec0 master hec0 is offline
Send a message via MSN to master hec0
go back to the mechaic and tell him he screwed up and fix the pump properly
Old 02-13-2006, 08:39 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
have u checked fuel pressure because it shouldnt drain back into the tank i beleave theres a valve that shouldnt allow the fuel to drain back into the tank but im not sure does it start up first thing in the morning after sitting for the night?
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 02-14-2006, 05:43 PM
sreilly77's Avatar
yea, it starts up fine in the morning, just its hard starting. i did take the car back to the mechanic and they put in a new fuel filter and fixed the fuel pressure issue. but it is still not right, so i am taking it back again tomorrow and they are going to put another pump in and they are going to fill the tank because i had to drain the tank under 1/4 twice now. so yeah this sucks.
Old 02-14-2006, 06:52 PM
Towncar's Avatar
Towncar Towncar is offline
General observation --
Following the line of thought were the pressure should'nt drain back to the tank, will it start right up if you first wait, Key On, for 10/15 seconds before cranking the starter?
This thought would assure the fuel pump pressurizes the rails before the starter cranks, thererfor proving/disproving the fuel is draining back to the tank.
-Steven
1996 Town Car, Cartier
Old 02-14-2006, 09:12 PM
sreilly77's Avatar
i did try that, just turning the key to the on position and giving the fuel pump time to pump up. the same symptoms still occur. i might add though, however, when i do get the car to run, and then shut it off and immediately turn it back on, the car will start right up. so the fuel is staying in the rails for a short time. i am wondering if the pressure is not where it is supposed to be probably because the new fuel pump is falty. i think the fuel pressure is around 15-20psi i'm not 100% sure. well i'm taking it back to the mechanic tomorrow. it will be fixed for free since this is the third time in the past 5 days that i had to bring this car back
one other thing i might add. i have noticed that since these problems have arose, every time i hit the gas pedal either at a light or a stop sign, i notice puffs of blue smoke coming out the back from both exhaust pipes. this happens when the car is idling for more than 30 second or so. and it doesn't matter whether the car is in park or drive. and the engine is hesitating slightly. does this have to do with the fuel pressure problems that i am having?
Old 02-14-2006, 09:14 PM
sreilly77's Avatar
when i say this, i mean it as that this is the normal fuel pressure for the car when the problems i am having are not present.
Old 02-14-2006, 09:17 PM
im just posting to say that somones listening and ur not ust wasting ur breath i have no bloody idea whats wrong im kinda new here
Old 02-14-2006, 10:36 PM
Towncar's Avatar
Funny you mention that
sreilly77 likes to entertain himself with these blow-by-blow experiences
Actually, it's a pleasure getting all this on the boards for lurkers looking for a fix.
-Steven
Old 02-14-2006, 10:40 PM
you know i have noting better to do i havent stopped refreshing this page since my last post its really sad
Old 02-14-2006, 11:16 PM
Towncar's Avatar
You're definately a sick man...
-Steven
Old 02-15-2006, 09:05 AM
srry to who ever posted this thread its gotten kinda off topic lol
Old 02-15-2006, 09:11 AM
sreilly77's Avatar
eh, doesnt matter if it gets off topic. i think it is just time for me to get a new car i mean my 95 has 200,000 miles on it i think i've pushed it far enough haha! its just the engine doesn't want to quit. that is actually the only thing workin well on the car. its everything else is going bad. all the little things. o well. i found this '03 Cartier town car real pretty with 37,000 miles. im going to try and pick that up.
Old 02-15-2006, 09:14 AM
so ur gonna scrap ur 95 tc? if you are ur only gonna get like 100$ for it
