Old 06-24-2002, 03:12 PM
CraigFL's Avatar
CraigFL CraigFL is offline
Question Help Required....
My home PC is down with a "missing operating system" message.
Here's the info...
I run NT 4.0 . When I had this problem, I also had a "bad memory" error which I fixed by removing the bad simm (EDO) and its corresponding "pair". Unfortunately, I still have the missing operating system error. I do have an emergency repair disk(not up to date) but it requires a 3-1/2 floppy (A which I have long since abandoned(I needed the interrupt for my CD burner). I have XP and would like to upgrade but I can't figure out how to install this or reboot with NT so I can recover all my hard drive info easily.
Any suggestions??
Old 06-24-2002, 03:47 PM
StageOneGalant's Avatar
StageOneGalant StageOneGalant is offline
Send a message via AIM to StageOneGalant
Jus put back in u're floppy drive
First.. U're PC CRASHED>> all data may be lost.
take out u're Burner, then put back in the floopy drive and boot with an NT boot disk or a 98 boot disk.. then jus choose the option boot with CD-ROM support and reload u're OS...NOTE: make sure u have u're CD-ROM DRIVE STILL IN<< not u're burner.
95 Mitsubishi Galant
Stage 3 FrankinStein Turbo, RalliArt Headers/Clutch , Custom Kat back exhaust system...etc....(enuff info )
Euribuni Body Kit, 18 in Konig Wildcards.
"Just Because words are free, doesn't mean u can use them Freely."
Winning isn't everything, it's the ONLY thing!!
Old 06-25-2002, 10:27 AM
Chris's Avatar
Chris Chris is offline
Oldie
Send a message via AIM to Chris Send a message via MSN to Chris
If you want to put on XP, just put it in the CD, go into the BIOS, make it boot from the CD first, then sit back, and watch as winxp comes up. You can install it over winNT, or choose a different folder. Then, you can boot up, save all your data that you need, then format and put XP back on (I say format because it sound's like there could be some major software problems/decay).
IF you don't have boot from a CD, then get a floppy, and put in WinXP. At the command prompt, enter i/386 to start the setup of winxp (setup won't run in dos)
You can live in a car, but you can't drive a house!!
MSN: [email protected]
Old 06-25-2002, 12:43 PM
CraigFL's Avatar
Chris...
I tried to boot XP from the CDROM but it didn't work
Old 06-27-2002, 07:44 AM
kris's Avatar
kris kris is offline
Off playing with fire.
Originally posted by CraigFL
Chris...
Is your computer setup to boot from a cd?
Old 06-28-2002, 07:00 AM
CraigFL's Avatar
I set it up to boot from the CDROM first, put the CD in and it wouldn't boot. It went there to read it but still came up with the error.
Old 07-02-2002, 08:40 PM
Chris's Avatar
Oldie
Sounds like a hardware issue... like a busted mobo
