Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 02-13-2006, 03:31 PM
dpcarroll dpcarroll is offline
Starting Problems
My 1999 Olds Cutlass will not start. Engine cranks but will not start. I am thinking maybe bad gas. The car wants to start but it still won't start. This is the first time that this has happened.
Can anyone help me with this problem?
Thanks in advance!
Don
Old 02-13-2006, 05:13 PM
niccaleb112602 niccaleb112602 is offline
Re: Starting Problems
check and make sure your fuel pump is working
Old 02-14-2006, 02:08 AM
Scootzilla Scootzilla is offline
Send a message via AIM to Scootzilla Send a message via Yahoo to Scootzilla
Check to see if the pump is working.If it is check to see how many psi you are getting from it.Make sure you have spark.
Scoot
Old 02-14-2006, 06:47 AM
Thanks guys,
I really appreciate the advice. I will check the fuel pump this weekend.
I forgot to mention;
The car did finally start last Friday when my wife, and I were leaving for work. It also started Saturday. I ran the car all day. I came out to start the car Sunday. It did the same thing. It would not start. I came out this past Monday to start the car for work, Again it would not start.
HELP!!
Don
Old 02-14-2006, 07:07 AM
well it also could be either a crank sensor or ignition module.
