Go Back   Automotive Forums Car Chat > Renault > Clio/Clio II/Clio III
Old 02-13-2006, 02:04 PM
granite2109 granite2109 is offline
Clio Extreme '53 reg - rear light & breaking problem
Hi, i'm looking for some advise on a few problems with my '53 plate Renault Clio Extreme (1.2 16V). Theres a few problems with the wiring on the car and i'm unsure how the solve the problems. When i have the car in reverse and apply the brakes, the rear fog lights in the cluster come on and the indicator and fog light symbols light up on the dash (this happens all the time). If i'm driving fowords as normal and apply the breaks the same thing happens but not all the time. The car has now started to make a high pitched noise (like a warning alarm) from the boot area when i'm driving as normal then apply the brakes. Lastly the rear fog lights sometimes come on by themselves, stay on for a day or two, then switch themselves off. The brakes are abs and seem to be working fine, they haven't failed and brake as they should.
Has anyone come across these sorts of problems with Clios before and if anyone has any information that could help it would be grately appreciated.
Thanks
Granite2109
Old 08-17-2006, 07:43 AM
ZOE2's Avatar
ZOE2 ZOE2 is offline
Re: Clio Extreme '53 reg - rear light & breaking problem
I Had A Simular Problem. Have You Moved Any Bulbs Around In The Back Light?
Old 08-24-2006, 01:30 PM
Hey ZOE2,
The problems sorted now. I hadn't touched any of the rear bulbs, the previous keeper had a towbar on the back then removed it before selling it, except they just hacked the connecting wires off. These wires were connected to the rear lights and everytime the bear wires (which they cut) touched the car chassis, this problem occurred.
Thanks anyway.
Old 08-24-2006, 03:32 PM
Did you sort the problem with yours?
Old 08-25-2006, 07:52 AM
ZOE2's Avatar
No Not Yet Cant Work It Out Atall.i Posted My Q On The Renault Forums But Hasnt Helped Really.
GIRL RACER
Old 08-25-2006, 09:21 AM
Ok, i'll try and help. Could you explain the problem in more detail please, does it happen all the time or only when your driving? Have you changed the bulbs at all? Has the car been in an accident that you know of?
I take it that you've put a system in, did this problem start happening after you intalled your amp?
Old 08-25-2006, 09:22 AM
.....installed your amp.
Old 08-25-2006, 09:33 AM
ZOE2's Avatar
Yes I Did Sort It,sorry! I Was Thing Of My Other Problem I Had!
Thanx Anyway. Clios Seem 2 Get Soo Many Problems!
GIRL RACER
