| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Worn timing gears/oil leak
My intake timing gears have a groove worn in them by the cam oil seal. Any idea how to get these gears for cheaper than 300.00 at nissan. Can the groove be filled with anything that would last?
Re: Worn timing gears/oil leak
aftermarket cam gears? i'm sure they're cheaper than what nissan wants for them anyway...
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
unless you go with adjustable cam gears you are gonna be paying out the ass for OEM ones. so the dealership or contact http://www.conceptzperformance.com can get them for you but last time i checked the full set of 4 cam gears is gonna run you about $800. some people go with aftermarket adjustable ones and they leave the cam gear cover off but these will need to be adjusted very often as in atleast once a week. i can see this getting ridiculously annoying...plus leaving the cam gear cover off, you risk the chance of a rock skipping up from the ground and tearing that timing belt in half. Edit: edited because of 2 different threads started... BTW: i dont know of any aftermarket cam gears that are not adjustable on the market yet but i may be wrong. i am pretty sure there are a few guys over on TT.net encouraging or working on a set to solve another problem when installed aftermarket cams.
ZedEx Crew Member #4
