Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-13-2006, 07:54 AM
protozee protozee is offline
Question what cold cranking amp battery do you guys recomend
I need a new batt. so what cold cranking amp battery do you guys recomend
for 2000 grtand ck? Brand? dealer recomends 600 amp.
Old 02-13-2006, 10:10 AM
JDPascal JDPascal is offline
Re: what cold cranking amp battery do you guys recomend
The rule of thumb for the minimum replacement CCA is double the engine size in cubic inches then allow for cold starting temperatures and other accessories useage like AC in hot weather and stereo equipment.
I would go for the highest CCA you can find and still fit without modifications. 600 seems a little on the low side for my preference. The one I just replaced was a 700 and I went to a 900 CCA this time.
JD
If ya can't fix it right the first time, how ya goin ta find the time ta fix it again????
Old 02-13-2006, 11:01 AM
neon_rt's Avatar
neon_rt neon_rt is offline
My rule of thumb, buy the biggest badest battery you can shoe horn into the tray. If it saves you one time from being towed or stranded, the few extra dollars will be worth it. Interesting point though, my '99 Caravan 2.4l came from the factory with a 600 amp, my '00 G Caravan 3.8l came with a 500, go figure.
After the 500 failed at 4 years of service, I replaced it with a 900.
Old 02-13-2006, 11:50 AM
yes the 600 seems a little on the low side for my preference too. The one I went to is a 875 CCA this time @NAPA Auto Parts $4 more then a mopar brand 600 CCA
Old 02-13-2006, 07:58 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
600 CCA is deffinately on the low side, the last battery I had 875 CCA. I just got a new Optima Red Top which is 800 CCA, but hey nothing beats an optima.
Old 02-14-2006, 09:10 AM
BenBB BenBB is offline
I agree with dksob81, i also have an optima redtop and it works great for starting when its cold, and i have a system running from it too. works fine.
Old 03-13-2006, 06:43 AM
FourPointZero's Avatar
FourPointZero FourPointZero is offline
I went with a AutoZone Gold 1000 cca. I almost bought an optima battery for it but decided it was too much(overpriced).
