Go Back   Automotive Forums Car Chat > Honda > JDM Motor & Parts info/chat
JDM Motor & Parts info/chat Discussions on Mugen, Spoon etc. Plus, info on motor swaps (b18 's, b16's h22's etc) and other JDM info!
Old 02-13-2006, 07:36 AM
whatup whatup is offline
Are 310cc too big?
I was changing the intake manifold on my 1992 Civic (B16a), and ended up breaking the tip of the injector. I went to Honda and they want 10,000 yen or $100.00 for a new injector. I don't want to pay that kind of money to replace the injector. What kind of injector from what other Honda can I use? There are plenty of cars in the junkyard, but none are B16a. I was also thinking of getting a new set of RC for around $275.00, but don't know if 310cc is too big (stock 240cc). Will this make the car run too lean? All I have on my car are cold air intake, Skunk2 throttlebody and intake manifold, exhaust manifold, and exhaust. Is 310cc too big?
Greetings from Japan
Old 02-13-2006, 05:09 PM
iVteC_PoWeR iVteC_PoWeR is offline
Send a message via AIM to iVteC_PoWeR
Re: Are 310cc too big?
310cc injectors are still small so it should run fine
Old 02-14-2006, 06:06 PM
S13wanabe's Avatar
S13wanabe S13wanabe is offline
Running a stock programmed ecu than yes they are too big. Your car will just run a little rich. 310cc injectors are a good size for your car, but you should go get a piggyback fuel controller to adjust the fuel flow, or get a fuel pressure regulator.
Old 02-15-2006, 12:02 AM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
go pick up some used stock obd1 240cc injectors.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 02-15-2006, 05:17 AM
I have a APEXi VAFC2 VTEC air flow/controller...Will that do the trick?
Old 02-15-2006, 05:44 AM
I've lived in Japan most of my life and have never heard anyone use obd1, but that's besides the point. I tried to do a search and I have seen b16A's and B18C's that both said obd1 and obd2. Can you please explain what an obd1 is or please direct me to a site where I can differenciate the differences between the obd's? Thank You.....
Old 02-15-2006, 12:31 PM
S13wanabe's Avatar
The VAFC should work. OBD1 was just the type of computer used on earlier vehicles in the US. I'm not 100% sure but I think OBD1 started in 1992 and ended in 1995 and then OBD2 took over. I'm not completely sure though. Any injectors off a B16 from 92-95 will fit right in.
Old 02-15-2006, 10:42 PM
AF - Advisor
if you are running a jdm b16. any obd0 or obd1 240cc injector will do.
