Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 02-13-2006, 12:57 AM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
Single Turbo (SpeedPimp84)
Originally Posted by SpeedPimp84
wassup I new to this, so bare with me. My question is I have a 1993 nissan 300zx 2+2, i was wondering instead of getting a twin turbo can I put a big single turbo to make up for the power , (along with others parts such as headers,exhaust.) Also does the nissan 300zx non turbo and nissan 2+2 have the same horsepower and engine?
when having a new idea please do not post in the stickys. please ask your questions by starting a new thread in the future.
ZedEx Crew Member #4
Old 02-13-2006, 01:07 AM
Z Cars Fanatic
Re: Single Turbo (SpeedPimp84)
Single Turbo has been done anc create big power but i must tell you it will not be easy...
custom manifolds will be the hardest part and figuring out where you want the turbo to be located. reguardless it is alot of work but has been done with great success. streetability is better with the TT set-up as they will usually spool better in most cases.
but if you are willing and looking to take on a BIG project, go ahead...results are very good.
check out this site for more info. there is a guy on there that did this set-up and then sold it to a buddy of his, it is not in a black car.
http://www.z32power.com
good luck
Old 02-13-2006, 07:11 AM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
im still trying to think of what you mean by "make up for the power." what power needs to be made up?
ZedEx Crew Member #2
Old 02-13-2006, 03:31 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
The Z31 Turbos had a single turbo set up, would it be possible to use their exhaust manifold for that?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 02-13-2006, 04:03 PM
Z Cars Fanatic
the way the Z31 passenger side exhaust manifolds wraps around, i dont think its possible for it to wrap around the engine on the Z32.
it is an idea though, it may only take a little modifying to get them to work.
it may just be better to get custom tubular manifolds for high power applications because if i am not mistaken, the Z31 manifolds are usually upgraded on the Z31 for those owners seeking decent power.
Old 02-13-2006, 06:57 PM
TerminalVelocity's Avatar
TerminalVelocity TerminalVelocity is offline
Send a message via AIM to TerminalVelocity
I would stick with the TT setup and just change the turbo's...
My new RHD project!
Solid Crew (Circa 2002)
Old 02-13-2006, 07:20 PM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
stock z31 mani's are said to flow up to 700hp... the only reason people change them is to relocate the turbo so they can fit a bigger one (SATAN from z31.com did this and ran a t66 turbo... hell of a mean car too, hit low 11's in the 1/4 and he's now shooting for 9's with his new setup)
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 02-14-2006, 04:02 PM
Z Cars Fanatic
my mistake...
i thought they were a choked up part on the Z31 like the Z32. for example, i have seen the stock Z32 manifolds (even ported and polished) flow 650rwhp but when tubular or high flow cast pieces were added, the difference in HP was nuts.
hmm...this thread makes me wonder where the best placement for a single turbo on the Z32 would be. i seen someone do it on the front side of the driver's side but the set-up didnt look efficient.
