Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-12-2006, 10:38 PM
jonathanc's Avatar
jonathanc jonathanc is offline
GMC Sierra Key Fob
Can someone please tell me how to program my new key fob? Its a 2001. Thanks jonathanc
Old 02-13-2006, 09:08 AM
JaVeRo JaVeRo is offline
Re: GMC Sierra Key Fob
Transmitter Programming
Important
All transmitters which are to be recognized by the remote control door lock receiver (RCDLR) must be programmed in a single programming sequence. If the system is placed in program mode it will erase all previously programmed transmitters upon the receipt of the programming signal from the first transmitter. Up to four transmitters can be programmed. Do not operate or program the transmitters in the vicinity of other vehicles that are in the keyless entry program mode. This prevents the programming of the transmitters to the incorrect vehicle.
You may program up to 4 transmitters, using either of the two following procedures:
Transmitter Programming Procedure (Method 1 - No Tools Required)
Close all the vehicle doors.
Insert the ignition key into the ignition lock cylinder.
Press and hold the door unlock switch.
While holding the door lock switch in the unlock position, cycle the ignition ON, OFF, ON, OFF.
Release the door unlock switch. The doors will lock and unlock to confirm the program mode.
Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of approximately 15 seconds, the doors will lock and unlock to confirm the programming of that transmitter.
Repeat the previous step to program up to four transmitters.
Turn the ignition switch to the RUN position in order to exit the keyless entry transmitter mode.
Operate the transmitter functions in order to verify correct system operation
You MUST program all remotes at the same time. Programming one new remote will change the code causing any existing remotes to no longer work.
James
Old 02-13-2006, 11:49 AM
Onblsht's Avatar
Onblsht Onblsht is offline
Authorized Vendor
Those instructions are correct from 99 to at least 04.
Replacement keyless entry remotes available here - up to 90% off -
All makes/models from Acura-Volvo, 1988-present -
http://www.OriginalKeyless.com
