Go Back   Automotive Forums Car Chat > Pontiac > 6000
Old 02-12-2006, 10:45 PM
smorris8 smorris8 is offline
6000 pontiac 1989 stalling and idling hard
I have a 6000 pontiac 1989. It was in geat condition but now it has an oil and transmission leak. The past day it has been idling and almost stalling at stop lights. I put oil and transmission fluid in it but it is still idling hard. Any ideas? Also does anyone else have any problems with this kind of pontiac? Thanks in advance.
Old 03-04-2006, 08:01 AM
tony36 tony36 is offline
Send a message via MSN to tony36
Re: 6000 pontiac 1989 stalling and idling hard
try an o2 sensor, they are cheap and can cause numerous problams like yours.
Old 12-07-2006, 09:44 AM
'88Pontiac6000GTP '88Pontiac6000GTP is offline
I have an 1988 6000, and I also have the same problem. I have been told that it could be the PCV Valve. I am currently in the process of changing it.
Old 12-12-2006, 11:56 AM
alan &marge pepper alan &marge pepper is offline
1989 pontiac 6000 pcv valve will make it idle rough. true. check air hoses for cracks for they can also cause rough idling.
for your oil leaks info on were your leaks are. would help us help you in how to fix them.
Old 12-13-2006, 10:25 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
Give this a shot too:
http://www.lesabret.com/phpBB/viewtopic.php?t=4054
The IAC valve is possibly gummed up.
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 04-12-2007, 01:54 PM
dcjredline dcjredline is offline
Try to test the resistance of the injectors. Very common GM problem.
