| 240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all. |
Brake Problems Z31 HELP!!!!
I just installed new calipers, lines, and rotors on my 300zx 85 2+2 the other day and now when I press the brake pedal it almost touches the floor.....after 2 or 3 pumps its back to normal.. It never did this before? Is it the brake booster gone bad or somthin else....Also I blead the system at least three times......HELP!!!
Re: No Brake Booster Z31
cracked master cyl?...happened to me...while driving..not too fun
but its about 100 for the master cylinder dunno if thats ur prob tho |
Re: Brake Problems Z31 HELP!!!!
if it happens everytime, you probably have a vacuum leak somewhere. whether its a hose or the tank itself you will have to find. just get under the hood and listen for this hiss. you can use some soapy water and put it on some places to see if there is a leak. if there is a leak you will be able to see it bubble unless it is a VERY large leak, then it will just blow the water out of its way. hope this helps. the Z31 owners should be able to help you more than i can when they get on...they may be able to tell you exactly where to looks and what not.
ZedEx Crew Member #4
ZedEx Crew Member #61988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc. blown turbo, under construction.. gt35 coming. |
alot of people dump small amounts of water in their throttle bodies. it cleans the carbon deposits out of the motor. it wont hurt anything; it will vaporize before it even gets to anything important.
if there's soap in it, it might start to eat at the lines... not saying it will, but it could start to deterorate it over time depending on the soap... that's why i like alcohol based accelerants, they evaporate without residue
![]() its just a recipe that my grandpa has used for 40+ years, from building cars to working on them. i just carried it on, it hasnt failed me once and i havent been using it for a good 7 years or so... it doesnt matter, they both work...i prefer to use mine and you prefer to use your's.
Its been like three days now and i have to pump the brake at least 5 times to get any pressure. I know there is a leak somewere because i hear the hissing around the master and/or the booster....id rather it be the master its alot cheaper but i have no brakes so somthin has to be done.....
