It starts.
It runs. Nothing appears to leak. However, two MINOR problems... 1. The "Service Engine Soon" light came on. At first, it flashed, then it stayed on. Any ideas? 2. I have a piece leftover. I'll try to take a picture of it and upload it to my wife's website so I can reference it here. However, just in case you can tell me what it is based on a description...here goes. It looks like a bracket of some sort. Imagine a 1/2" long piece of angle-iron. Each flat surface is about 1" long, with a hole on each surface. One hole is threaded. Any guesses? I used "GUNK" engine oil additive. I let it run for a few minutes. I ran out of time, though. I'm going to start it back up tomorrow night and let it run long enough to warm up, then change the oil and filter. After that, I'll take it for a little ride. New plugs, wires, PCV valve, air filter, coolant, serpentine belt and radiator hoses. When I started it, it ran a little rough, then settled right down to a very low idle. "Purrs like a kitten." So, I'm not TOO worried about the service engine soon light or the bracket, but I still want to get them figured out and fixed. Thanks for all of your help. I'm probably going to post a few hints over at the Venture forum sticky that I learned along the way. |
Re: Intake manifold SUCCESS...well almost
I would guess that bracket probably is mounting for the alternator.
one end should fit into rear of the alternator with mounting bolt and the other end should be top of left rear or #1 cylinder intake upper plenium bolt. One of the plenium bolt should have extra thread past mounting surface. |
The SES light is probably due to a misfire. Scan the computer and get the code but since the light flashed first that usually indicates a misfire condition.
I learned and next one I did I put it in the bag and marked it. |
I think I'll take it to AutoZone and have them put it on their scanner, but I need to figure out what's going on. I suppose it COULD cure itself with time, like if I got too much dielectric grease on a plug or something, but I'd like to get it fixed and "enjoy" the new plugs and wires and stuff. Any ideas? It's not running rough enough to be mixed up fuel injector wires or anything crucial like that. In fact, it seems to run pretty smoothly when you get out and go. It just idles rough. Also, the bracket doesn't go to the alternator. I checked back there, and there is no place it can connect to the alternator. Like I said, I'll try to post a picture soon. |
It is possible that the injector wire is not full connected or that one of the wires has broken and only making partial contact. Once you get it scanned you will be able to tell what is really going on and you can direct your efforts at that particular cylinder. I doubt that the dielectric grease is your problem as it shouldn't interfere with connections.
I'll take a picture of it tonight if I remember, but until then, if you can take a picture of the bracket that would help.
Vinyl adds horsepower, right? |
Like I said before I forgot the darn thing when I was doing mine and took me 2 days to figure out where it fit. |
OK. It's time for some confession.
On the misfire...I evidently didn't get the boot on plug 5. Duh. I decided to take the car to a good independent a few doors down from my office this morning to find the misfire problem, rather than to try to figure it out on my own. He put the sensor on the van, and it came up cylinder 5. He put the van up on the rack, reached up from underneath and could feel the top of the plug. How in the world could I be so stupid? Don't answer that. |
I don't know - you saved yourself a lot of money doing this work yourself, and that sounds pretty smart....most people won't even try repairs anymore.....Glen
CDRU that is correct bracket but mine is slightly different shape. I think it depends if you have rear AC or not. If you have rear AC you get bigger alternator and hence different bracket.If you have rear AC it looks a bit like ? but turned left 90 degrees.
Oh, THAT way!
I was thinking about it going straight back (toward the firewall) and attaching to the alternator. There's a bunch of stuff in the way, but I'll check that tonight. Definitely a possibility. Mine doesn't look exactly like that. A little smaller and shaped like a ? like shogunl said. |
