Old 02-12-2006, 07:11 PM
malaudi malaudi is offline
94 Lesabre gas mileage terrible
gas mileage dropped from 550 + Km on a tank to about 400 Km. SES light comes on sometimes at no particular time. It does have some surging at a constant low speed, but acceleration and power is good. Did a tune up with plugs and wires and filters, but no change. Any ideas please ?
Thanks
Old 02-12-2006, 07:44 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: 94 Lesabre gas mileage terrible
Thanks
How many KMs on your 94? (could you convert to miles if you don't mind?) Have you checked for codes?
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 02-12-2006, 08:11 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
In recent years, manufacturers have indirectly given the O2 sensor more control over fuel delivery. You need to get it hooked up to a scanner and check 02 sensor output. When a vehicle exhibits drivability issues such as; bucking, surging, and erratic SES illumination, the codes retrieved, may be adaptive fuel codes or straight up oxygen sensor codes. The oxygen sensor or O2 sensor is used to sense the exhaust for a rich or lean condition. The oxygen sensor produces its own voltage ranging from 0 to 1 volt. The computer receives the signal and adjusts injector on time to compensate. Voltage above .450v is rich and voltage below .450v is lean. The sensor should switch regularly above and below .450v. If the oxygen sensor stays below .450v engine is running lean or sensor is bad or shorted to ground. If the oxygen sensor stays above .450v engine is running rich or oxygen sensor is bad or shorted to voltage. The oxygen sensor behind the catalytic converter monitors the converter effectiveness. Because it is burning any excess hydrocarbons it will use up the oxygen in the exhaust making it show higher voltage with less fluctuation then the front oxygen sensor. If the catalytic converter is bad, the rear O2 sensor will fluctuate the same as the front O2 sensor and set a code for inefficient catalytic converter. OBD2 systems can easily change fuel delivery by more than +/- 30% and this can cause problems when this much of a change isn’t really needed. Some systems have been seen going beyond 40%!
Old 02-13-2006, 11:38 AM
Originally Posted by HotZ28
In recent years, manufacturers have indirectly given the O2 sensor more control over fuel delivery. You need to get it hooked up to a scanner and check 02 sensor output [typically 1,070 mv]. When a vehicle exhibits drivability issues such as; bucking, surging, and erratic SES illumination, the codes retrieved, may be adaptive fuel codes or straight up oxygen sensor codes. Poorly operating 02 sensors, prevent proper feedback to the PCM and therefore the engine will remain in closed loop, operation. (Your car becomes a gas hog in closed loop)! OBD2 systems can easily change fuel delivery by more than +/- 30% and this can cause problems when this much of a change isn’t really needed. Some systems have been seen going beyond 40%!
HotZ
Does a 94 have OBDII?
Regards
Dan
SW MN
Old 02-13-2006, 12:55 PM
troy1 troy1 is offline
AF -Advisor
94 OBDI
95 Some OBDI others OBDII
96 & newer OBDII
Old 02-13-2006, 04:16 PM
Loekee75's Avatar
Loekee75 Loekee75 is offline
Send a message via Yahoo to Loekee75
94s have the diagnostic connector for OBDII even though it is still an OBDI system.
http://www.cardomain.com/ride/2653398
1992 Buick Park Avenue (Daily driver)
2001 Saturn SL1 (gas saver)
Old 02-13-2006, 07:11 PM
Yes this makes it tough to see any trouble codes. I guess by elimination I should replace the o2 sensor?
Old 02-13-2006, 08:20 PM
HotZ28's Avatar
AF Moderator Elite
Either that, or find a shop that has a OB1 capable scanner with the correct cable for the OB11 ALDL. Any shop with a KAL (Actron) 9640B or a SnapOn MT 2500 with the correct key and cable, could do that for you. It would be cheaper and less frustrating to just change the 02 sensor and see what happens.
Old 04-02-2006, 09:02 PM
David DeVoe David DeVoe is offline
I took my 94 to Auto Zone and they hooked up a scanner to it no prob. Now I.m going back to have them check the 02 sensor. My mileage has dropped recently too. Glad I read this post.
