Old 02-12-2006, 02:14 PM
fordfool fordfool is offline
98 taurus trouble codes
my car has been running rough and im getting some varying codes. new plugs, new wires, new thermostat, pcv, air filter and ran injector cleaner also. i have noticed more than normal condensation comming out of the tailpipe and some occasional first start lifter or valve chatter. oil level is good, and there isnt any water on the dipstick. the codes that ive been getting are, p0305 "cylider 5 misfire detected", p0340 "camshaft position sensor circuit malfunction and p0411 "secondary air injection system incorrect flow detected" i have an AutoXray scan system so i can monitor and scan and reset the computer, but i have not had training in proper use of the equip.
Old 02-12-2006, 03:00 PM
TaurusKing TaurusKing is offline
Re: 98 taurus trouble codes
I was looking thru my book, the first code could be directly related to the second code, faulty cps did show up as a possible reason for misfire,, the third code could be any number of things related to air injection system, I think if I'm reading correctly there is more than one type of system available, could be a belt-driven or electric air pump, 0411 shows on both, there's a relay or two in there, I believe there's a fuse for the circuit also, some have air bypass or air diverter solenoid, check your system for anything loose, broken wires, air line, etc. There's a couple of guys on here that are good with the electrical end of it..
Old 02-12-2006, 07:04 PM
robroy55 robroy55 is offline
I am having the same type of missfire in my 2002 24V with 37800K. Could someone tell me what a "CPS" is and where I can find it on my duretec engine.
Thanks for any help Folks !!
Rob Roy
Old 02-12-2006, 07:52 PM
I want to say it's located on the front cover towards the top up by where the cams are, there may be a couple of different styles,, I think one of the engines, not sure if it's the 24v or the 12v, requires a special tool to make sure the cam position sensor is properly aligned upon installation, something to do with the fuel system being out of time with the engine, possibly causing damage.. I'm pretty sure it's the 12v engine... I'll look it up, in the meantime someone else will most likely know more,, I think there are other threads on here about failing camshaft sensors, seems not too uncommon... I think that the injectors and ignition use this signal so if it's wacky could cause issues.
Old 02-13-2006, 08:17 PM
thanks for the reply.
i replaced the cam sensor . the drive assy. looked great. computer still reads misfire on #5(p0305). pulled #5 plug and it was a little oily. these are all new bosch plat. plugs. i checked a couple of others and they were perfect. after i replaced the cam sensor(2fixed bolts, no alignment needed, per the manual) i now have a huge amount of white smoke and major condenstation comming out of the exhaust pipe. any thoughts. maybe a head gasket? the exhaust does smell like antifreeze. no oil on the dipstick. heat never worked right. maybe #5 injector? coil fires like a demon all around! oh yeah, the p0411 code was the rear bank diverter valve hose was left off! duh!
Old 02-13-2006, 11:01 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
You could possibly have a bad head gasket or other issue. However, if you have coolant leaking into a cylinder, the spark plug in the offending cylinder will usually be very clean. Coolant (and water) in a combustion chamber has a tendency to really clean things up.
Is there a chance that the "oily" residue on the spark plug is unburned fuel? Maybe try swapping that plug with one from another cylinder and see if the residue and misfire code follow the plug or stay in cylinder 5. If it follows the plug, then you may have a bad plug. If it stays on cylinder 5, you may have a bad plug wire for cylinder 5, or you may have a problem with the cylinder.
The white smoke and condensation you are seeing could possibly be unburned fuel from cylinder #5 not firing. The catalytic converter will convert some of the unburned fuel to water, but it is hard on it to try to convert large quantities of unburned hydrocarbons to water vapor for very long.
Can you find someone with a cooling system pressure tester? If so, try pressurizing your cooling system and watch it for a few minutes. If the pressure drops, you have a leak somewhere. Could be head gasket, could be cracked block, could be a leak elsewhere in the system. However, if it maintains pressure, you probably don't have a head gasket problem.
-Rod
Old 02-14-2006, 06:55 PM
I've read on a couple of other forums, bosch sparkplugs don't necessarily work well, seem to have problems with misfires, replace them with Motorcraft plugs.. the general consensus from the mechanics was to stick with oem, might cost more but less trouble..
Old 02-15-2006, 09:28 PM
im gonna do a compression test and put in motorcraft plugs. maybe it will help. still getting a p0340 code. i replaced the sensor and the shaft looked brand new.
Old 02-16-2006, 06:47 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
If someone has replaced the syncronizer shaft previously and did not index it properly, it will continue to give you that code.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 02-16-2006, 07:36 AM
ill try to check the index of the syncronizer shaft. i believe it should be 38 degrees from the center line of the motor. if thats correct then you shouldnt have to have the alignment tool. any thoughts?
Old 02-16-2006, 06:13 PM
ive replaced all the plugs with Motocraft plugs and it made zero difference. #5 plug is not firing. i have good fire at the plug, but the cylinder is not firing. could a faulty injector cause this problem? when i pull the #5 plug it appears to have just a little bit of water on the electrode tip. the plug doesnt smell like gas, but if just isnt firing it would and if the injector was clogged it wouldnt, right?
Old 02-16-2006, 10:38 PM
shorod's Avatar
SHO No Mo
I would expect that if the plug isn't firing, but the air/fuel mixture is, the plug would be moist. If you are certain that the cylinder is not getting fuel, then it could be a bad injector, plugged injector, or bad wiring not signaling the injector to fire.
You may be able to borrow a Noid light set to test the wiring to the injector. You will also want to borrow a compression tester to make sure the cylinder has proper compression. To fire, the cylinder needs air, fuel, spark, and compression, and all must be at the proper ratio/level and occur at the proper time. Since the engine runs and only one cylinder is reporting a misfire, the timing is probably correct.
-Rod
Old 02-17-2006, 06:07 AM
ive got an noid light set and ill check the connector. i did a compression test yesterday and that cylinder was a little low, but the manual said minimum of 100 psi and it was 115 psi. if ive got to remove the injector, how involved is that?
Old 02-17-2006, 01:06 PM
shorod's Avatar
SHO No Mo
I don't see where you ever specified which engine your Taurus has. I suspect though the most difficult part of replacing an injector is writing the check for the new injector and possibly finding the spring lock tool to release the fuel line from the fuel rail. Since you have a noid light set, it wouldn't surprise me if you have the spring lock tool as well.
-Rod
Old 02-17-2006, 01:57 PM
its 98 ohv and no i dont have the spring lock tool, but i have no problem buying tools. a man's tools are his toys. my wife dont understand but who cares!
