Old 02-12-2006, 01:12 PM
wakeboard1026 wakeboard1026 is offline
Send a message via AIM to wakeboard1026
apexi auto timer
Hey has anyone bought the apexi auto timer for their na yet? And if so what wiring harness will i need to use in on a 97 na? and aside from the wiring harness will any other "Tapping" be neccessary to utilize the a/f ration funtion ( like into the o2 sensor) or does everything go throught the harness?
Style like Morphius289... lol
Old 02-12-2006, 02:31 PM
Igovert500's Avatar
blue + red light magnet
Re: apexi auto timer
Can you post a link to the part you are talking about? I'm hoping you aren't talking about a turbo timer for your NA.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-12-2006, 05:22 PM
http://www.raceperformanceparts.com/...744&language=1
Its an auto(na) timer and turbo timer. It can be used for either.
Im in high school, always coming and going in a rush, and i dont want to have to wait for my car to cool down 7 times a day. and the air/fuel function doesnt hurt.
Old 02-12-2006, 06:11 PM
Igovert500's Avatar
ok,
1) that is a turbo timer, not for NAs. The 'auto' part is part of the name, it doesn't mean for auto trannies. And unless you have a TT conversion, there is zero need for this.
2) The a/f ratio function is junk, it says "theoretical". It is judging based on O2 sensor voltage, it's not a wideband, so I wouldn't even trust it.
Save your money for a part you actually could get use out of.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-13-2006, 06:07 AM
I never said anything about an automatic trans. the word auto refers to Naturally Aspirated, and i think its a good investment of money to insure my engine has proper warmup and cool down time as that is common knowledge.
Any ways all i want to know is if anyone knows how to install it?
Old 02-13-2006, 04:18 PM
Igovert500's Avatar
Seriously, not trying to be a prick here, but that is a waste of money. The auto part doesn't refer to NAs. It's a turbo timer. End of story. It's sole purpose is to let the car run while the keys are out of the ignition, so that the oil can cool down while still circulating. That way it doesn't just sit inside the turbos and bake. Don't believe me...I'll bet you've only found harnesses for the TTs and not the NAs...that is because they aren't made for the NAs.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-13-2006, 04:24 PM
xXxRocker5150's Avatar
xXxRocker5150 xXxRocker5150 is offline
Send a message via AIM to xXxRocker5150
^that's what I was gonna say too. Even if you did have a turbo, I still wouldn't waste my money on it, becuase all you really have to do is let the car idle for 30 seconds after you park. You can do that to your n/a too if it makes you feel better, but all you're really gonna do is waste more gas.
Georgey on the subject of midget beastiality pornos
Originally Posted by 1viadrft
I've seen a video or two out of curiousity.... those damn midgets are hung! But then the donkey walks in...
Home Puta's 4Life Crew Member #1
R.I.P Andy, you will be missed by all.
Old 02-13-2006, 08:09 PM
alrite i get u, its just my 2nd/3rd? uncle runs a hot rod shop and i just learn from him. we are both picky about proper care ( i cant help it) and i just wanted to be able to let it cool down without wasting my time. I usually wait for the oil p. gauge to drop bfore i turn it off and it can take 45 or so seconds, and thats why i wanted it. but if you guys say its okay to just turn it off after a hard run then i guess i gotta listen to u, u are a "moderator" lol.
Old 02-13-2006, 08:53 PM
Igovert500's Avatar
You are not hearing me. I didn't say turn it right off after a hard run. All I've been saying is it is a TURBO timer not an NA timer. It is a part made for a TURBO car. I understand your intentions, and they are great. But you are missing the whole point. It's like saying, I want a BOV for my NA.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 02-16-2006, 01:53 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
its common sense that will tell you not to turn your car off right after a hard run. you might cruise around easily afterwards before shutting her down. and you could also just let it idle for about a minute or two. turbo timers, as Igovert said, are ONLY for cars with Turbos. therefore, this would serve you no purpose. furthermore, i believe turbo timers just to be a waste of money, as most people think. put that couple hundred bucks toward a more meaninful modification for your car.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 02-16-2006, 08:33 AM
AutostradaVR4 AutostradaVR4 is offline
aite wake, i hear ya and i get what your saying.
If you REALLY dont have time to let your car cool after beating the nuts off of it, yes, i turbo timer should work. But i wouldnt go with anything expensive. get the cheapest one you can find.
as for the install, you just tap into your ignition wire from the ECU, and probably your e-brake wire (all this depends on model of turbo timer). but like i said, get a cheap basic one, you dont need to waste 200 bucks on a fancy one. most of the other functions on those are garbage like Igo said. also, the more functions, the more wires you gotta tap into...
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-17-2006, 09:22 AM
aite thanks blink, im still debating it, but in the 30% chance i get one ill get the cheaper apexi. THanks
Old 02-17-2006, 11:52 AM
Hotshot8792 Hotshot8792 is offline
hahaha, wow, this thread just made my week
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
