Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-12-2006, 09:32 AM
CAPRICE LIFE CAPRICE LIFE is offline
Send a message via AIM to CAPRICE LIFE
Question Missing At Driving Speeds
I Have N 82 Caprice That Idles Good But When I Drive It,it Misses Throughout Driving Range...it Also Hesitates When I Press The Gas Pedal Down Like Im Not Gettin Throttle Response Like I Should...its A 305 Wit A 2bbl Carb.....350 Turbo Tranny....any Help Will Do Justice
IF IT AINT BROKE,DONT FIX IT
IF IT IS ASK ME
Old 02-12-2006, 10:51 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Missing At Driving Speeds
#1, off-topic, please don't capitalize every word. It is annoying!
I'll answer your question with another question, does it backfire through the carb ever, especially when it's at its worst with the misfiring? If so, you may have a worn out camshaft.
Before we go there, however, let's do some troubleshooting. Check your distributor cap and rotor for carbon arcing, or cracking. If you see any, replace both. The rotors on the cap-in-coil HEI distributors tend to 'burn through' right under the carbon button in the cap, this allows the spark to jump through the rotor to ground on the centrifugal advance mechanism. Lots of misfiring.
Check your spark plug wires. Sometimes, especially with the exhaust manifold layout on these cars, the wire will rub the manifold and burn through. If there's a valve cover gasket leak (or rear intake seal leak, anything that produces an oil leak from the top of the engine), oil can get on the plug wires and over time, this causes them to swell and misfire.
Check your ignition timing with a good induction pickup strobe timing light, with the wheels blocked, the car in drive and the vacuum advance line pulled and plugged. It should be at 8 degrees BTDC. If it's more, then you could be experiencing detonation which kills performance (and engine parts), mimicking a misfire.
If it was an older non-electronic ignition, I'd tell you to check your points and the dwell angle. But it's HEI, so you might check the ignition module and/or pickup.
Anyways it wouldn't hurt to check the carb as well, but I have a feeling this is either ignition related, or camshaft related. Good luck in getting it tackled.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-12-2006, 11:59 AM
thanks for the reply(no caps now)lol...anywayz theres nothing comin thru the carb at all....timing is right on point....i think it may be the distributor cap and rotor button as well.....what bout the carb gasket?will that make it misfire?theres no oil leak....at it runs smooth at idle.....thanks
IF IT IS ASK ME
Old 02-12-2006, 01:05 PM
Cyrix_2k's Avatar
Cyrix_2k Cyrix_2k is offline
The same thing happens on my '89. It was supposed to have a new cap, rotor, wires, and plugs when I bought the car, and it had the same problem then. It does knock every-so-often such as when I'm driving up a hill and it stays in OD; basically it happens at times when there's a high load on the engine at low RPMs.
1996 BMW 318i Convertible
1989 Caprice Brougham - 305 V8, TH-2004r - FOR SOLD!!!
Old 02-13-2006, 11:19 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I agree with checking the cap, rotor and wires first. Look at the gas line where it comes into the fuel pump, sometimes they dry rot and suck air. Just to rule it out, change your gas filter, they're only a few bucks and takes 10 minutes to change.
Bob
