Old 02-12-2006, 08:29 AM
Adasm Adasm is offline
Send a message via AIM to Adasm Send a message via MSN to Adasm
93 euro, odd problems
this is an odd question, but i bought this car and had it certifired and e-tested not long ago...so, everything should be fine...but:
for some reason, it looks like the rear of the car is sitting lower than the front, i mean, the clearance between the fender lip and the front tire is larger than the clearance between the rear fender lip and the rear tire...is this normal? also, my e-test didnt exactly pass legally, my mechanic put it through for me after he found out what the problem was (computer isn't actuating the egr valve)...so he tells me i need to replace the computer...has anyone done this before? is it hard?
Old 02-12-2006, 08:49 PM
robbie7290 robbie7290 is offline
Re: 93 euro, odd problems
My '93 also rides low in the rear, on mine, the rear fiberglass spring in the rear has flattened a bit, they all seem to do that, not sure why. My last Lumina did it too (a '92). You can try replacing it for around $300, not worth it to me.
