Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 02-12-2006, 08:21 AM
C-rag C-rag is offline
97 corolla Tach Wiring?
I have a 1997 corolla that I bought a tach for, and i'm wondering if anyone knows how the wiring goes to the distributor, or which wire it is. Any feedback or wiring diagrams would be appreciated!
Old 02-12-2006, 09:51 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 97 corolla Tach Wiring?
read my post on non tach to tach install... its good
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 02-12-2006, 10:45 PM
joykill joykill is offline
if its an aftermarket tach i beleve there are four wires
black:ground
red:acc
yellow:12v power(straight to battery)
green:negative side of ignition coil
671 ISLAND ROOTS
Old 02-19-2006, 09:42 AM
i want to know what is considered the negative side of the ignition coil? does anyone have a detailed summary? or a picture or something? It's an aftermarket tach, that gets mounted on the dash of my car. I want to know how to hook it up to the distributor, I have the rest figured out.
Old 02-19-2006, 07:47 PM
VDUBMAN
you can just tap off the ignition module on the wire I posted on for my post. Its about 15-20 posts down or so "non tach to tach install."
One of the pictures I took of the ignition module and the wire to tap off of for a tach signal.
Old 02-19-2006, 08:11 PM
the negative side is clearly marked with a (-)
671 ISLAND ROOTS
