Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 02-12-2006, 12:37 AM
materialboi materialboi is offline
door lock
for some odd reason my door lock in my driver door will not work if it gets a lil cold out, it's really finicky, when i press the power lock button the door doesn't even make a noise some times. i don't know if it's because it's cold it's not working right or there is actually something wrong with the actuator or something
thanks
ritchie
Old 02-12-2006, 09:19 AM
thumpin455 thumpin455 is offline
Re: door lock
All of your recent problems you have posted (dome lights, dash lights, power windows, door locks) are caused by the wiring harness that passes thru the body into the front of the drivers door. There are alot of wires in this harness and the constant opening & closing of the driver door will eventually wear down the wires causing an open or short circuit. Sounds like you have a couple of each. Maybe someone who has done the repair will reply with tips on the best way to get better access. May or may not have to remove the door panel to get more slack to work with ??
Paul
1995 Aurora (metallic gray w/graphite interior, heated seats)
1966 Toronado (black on black, chrome wheels, Olds 425)
1971 Lemans Sport Conv (w/solid lift Olds 455, very fast)
2006 Impala (my company car & daily driver)
Old 02-13-2006, 04:13 AM
Re: door lock
if you read my post all the problems but the door lock are in my friend's car, not mine, my car is fine outside of the lil door lock issue
