Old 02-11-2006, 11:10 PM
basketballbest25 basketballbest25 is offline
Crossed Battery Terminals..help!
Alright, call me what you want, but after SUCCESSFULLY bleeding my clutch line and fixing my clutch.. I somehow crossed battery wires and yeaaaaahhh.. bad shit. Somehow one of the negative wires got caught up in the positive wire group... so after the postive side was all connected and I started to connect the negative side there was spark show. When the cloud of sparks blew up in my face, somehow the battery wire dropppppped right onto the terminal.. still making the cross and sending sparks... and stuff everywhere. Somehow, the groud wire on the frame (at the back of the engine, going from the firewall to the frame, halfway left to right) caught on fire for a split second before I could finally grab that wire off of the negative terminal. So as you may suspect, after I reconnected the battery CORRECTLY... there was nothing. No interior lights/radio and nothing when I turned the key... dead. SOOOO... any ideas on what it will be/cost? I had it towed to the shop.. but I was wondering how bad I messed things up.
Thanks guys for any ideas, like I said, I know Im and idiot.. honest mistake.. I suck.. but I'd appreciate the help. Thanks.
Old 02-12-2006, 04:18 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: Crossed Battery Terminals..help!
As long as you didnt actually burn none of the wirign harness you probably fried the batery and blew some fuses. You may very well be okay.
Old 02-12-2006, 11:37 AM
well I hope thats all it is, thanks
Old 02-12-2006, 01:59 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
I'm gonna put my money on quite the opposite outcome. A flux for that length of time for sure fried alot of crap. In some cases the car will try to ground throught the acclerator cable and weld it to the gide frame, you probably blew alot of fuses and relays and I dont know if the car has to be ON for the ECU to fry but thats a possibility too.
Go ahead and get it inspected and best of luck to ya.
psst, pssssst hey Stealthee, 20 bucks says he wont be able to fix it and have to get rid of it, I have a pool going you want in?
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 02-12-2006, 02:10 PM
AutostradaVR4 AutostradaVR4 is offline
spend the money for the fuses before you assume the worst.....but sadly, theres probably a pretty good chance some other stuff is cooked like musashi said...
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-16-2006, 09:15 AM
SHO411's Avatar
SHO411 SHO411 is offline
I agree with all, their could be some serious damage, but before letting them fix anythin, replace ALL fuses in the fuse box, and ALL the relays, and see if that helps, after doing that, then let them check it. Other wise, they'll probably charge you for diagnosing that your fuses are all burnt up, then replace them, then they'll probably charge you again to determine what else was messed up. Good luck, hope nothing serious.
Ain't this the pretiest motor or what?
Fines are the fee you pay for the privilege of driving as fast as you want
Old 02-17-2006, 12:27 AM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
You probably just blew your 120 amp main fuse.
I did the same thing once, only I tightened it down, and tried starting the car with them reversed. Just the fuse blew. Once that fuse blows, you can't get power into the car to hurt anything else.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 02-17-2006, 10:24 AM
SHO411's Avatar
cool, so then he might just avoid some very costly repairs.................. Do that, and next time Zip the damn things before you start a small fire and burn shit up.
Old 02-17-2006, 06:40 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
damn.. good luck and let us know.. im interested to find out what damage was done..
